Old 09-12-2017, 03:53 PM
YENKO DEUCE REGISTRY's Avatar
Default Valve Covers with Poly Locks for SBC
Looking for ideas on vintage style valve covers for SBC that will clear poly locks....
Marlin
Old 09-12-2017, 04:37 PM
How much higher do they need to be and would adding base spacers be a solution?
Like these or others similar...
http://www.ebay.com/itm/SBC-Small-Bl...-/132319747382
Old 09-12-2017, 05:50 PM
I guess that could work, was thinking maybe some vintage Edelbrock scripted ones too - just not sure if they would high enough, going for a bit of a Day 2 look on Danny's '67 Camaro....
Marlin
Old 09-12-2017, 06:38 PM
Justoldchevys Justoldchevys is offline
Old mickeys should clear
Old 09-12-2017, 06:41 PM
Here is a set on ebay.
https://m.ebay.com/itm/VINTAGE-M-T-M...257Ciid%253A10
Old 09-12-2017, 09:15 PM
earntaz earntaz is offline
Yup -- if the M/Ts have the drippers ... cut em' off ... TAZ
Old 09-13-2017, 12:22 AM
L_e_e's Avatar
L_e_e L_e_e is offline
You can broaden your valve cover selection by installing short poly locks.
Old 09-13-2017, 01:36 AM
Short locks with roller rockers on this one. I've done it with iron heads and aluminum heads which already have taller rails. Add a thicker gasket and you can hide the rockers with lower profile covers if you like.
I'd bet that short poly locks with thick gaskets would allow you to use the old scripted Edelbrock covers. I like the Holleys and MT's too.
Old 09-13-2017, 02:38 PM
wrench wrench is offline
PM sent
Old 09-13-2017, 05:52 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
I have the 9 finned aluminum Cal Customs on my AFR's. And they clear real nice with a single cork gasket
