Free.
Worked fine. Overheated the first time I took it on a long trip, but it turned out to be a defective T-stat. It was 35 degrees F. Since replacing the T-stat it has NEVER once overheated again.... BUT when I am towing a heavy load (over 4000#) it runs hot on 100 degree days. That is why I just replaced it with a true four row aluminum radiator. For what it is worth, the last time I towed a car, the load was 3900# and the outside temp was 97F. It never got over 195 degrees, and I drove 75 all the way home, about 150 miles. I just wanted more safety margin. If you are not towing, you are probably fine, although I never have run the AC with it, as I have not even installed my compressor. This one is aluminum core with plastic tanks and cooling ports for auto trans. Obviously you can use it in a manual trans car, and just plug the trans cooler ports. I still have the box i got with the four row radiator, so can pack it up in that. Just pay actual shipping. I use pirate ship for stuff like this. Guessing (only a guess... my crystal ball is in the shop) shipping will be about $20 to $25. If no one here wants it I will put it on CL for free. It is a little over 28 inches from tank ridge to tank ridge, so if you have a Chevelle, GTO, Cutlass, etc. (pretty much any A body) from this time period and it did NOT come with factory AC, you can still use this, but you will need to buy a new top plate for the wider radiators.
Don't believe everything you read on the internet ... Ben Franklin Last edited by Lynn; 04-12-2024 at 10:39 PM. |
The Following User Says Thank You to Lynn For This Useful Post: | ||
PeteLeathersac (05-18-2024) |
Hi if you haven’t gotten rid of this I’ll take it
And use it in my 1972 El Camino Thanksm |
Still have it.
Send me a pm with your shipping address.
Shipped yesterday; so no longer available.
It arrived yesterday! Thank you sooooo much!!
You bet.
Lynn rocks! ![]() ![]() ~ Pete .
The Following User Says Thank You to PeteLeathersac For This Useful Post: | ||
67since67 (05-18-2024) |
Thread Tools | |
Display Modes | |
