Old 09-17-2023, 01:56 AM
jer jer is offline
Not suggesting this for you, I'm sure I'd just be happy with the new cap, but someone could just plug a t fitting in the bypass hose and check pressure.
The Following User Says Thank You to jer For This Useful Post:
Arrowsmith (09-17-2023)
  #152
Old 09-17-2023, 02:03 AM
Arrowsmith's Avatar
Smile
Good tip.
I can't use it for my car because I don't use a bypass hose (no machined port in the intake). I use a drilled thermostat from Stewart. That part works great.
Old 09-17-2023, 05:39 AM
427.060 427.060 is offline
I also have a Stewart thermostat as well as a Stewart water pump. I don't remember what temp the stat is.
1968 Beaumont SD396
The Following User Says Thank You to 427.060 For This Useful Post:
  #154
Old 11-09-2023, 05:41 PM
'69Novajoe's Avatar
'69Novajoe '69Novajoe is offline
Default Subframe connectors
Hey Wayne, I've decided to install subframe connectors, as you did, on my Nova. Without looking first, did you encounter a problem with the parking brake cables??
I ain't as good as I once was, but I'm as good once as I ever was.
The Following User Says Thank You to '69Novajoe For This Useful Post:
Xplantdad (11-09-2023)
  #155
Old 11-09-2023, 06:43 PM
Arrowsmith's Avatar
Smile
Hi there…they fit nicely with the Competition Engineering connectors I used. If you click to post #137 of this thread you can see the front of the routing. Zero issues at the rear as well….if you jump to the cars for sale section, my ad is still up for the car (although no longer for sale).. there are several good images of the chassis and park brake cables. Hope this helps
The Following 2 Users Say Thank You to Arrowsmith For This Useful Post:
'69Novajoe (11-10-2023), Xplantdad (11-09-2023)
  #156
Old 11-09-2023, 06:58 PM
'69Novajoe's Avatar
Thanks for that Wayne!! Also, where were you able to source the stainless parking brake cables??
  #157
Old 11-09-2023, 09:18 PM
Arrowsmith's Avatar
Smile
IIRC, they came from Inline Tube.
  #158
Old 03-27-2024, 08:26 PM
'69Novajoe's Avatar
Question
Hey Wayne, another quick question. I know you used different a-arms than what I'm using, but I'm encountering a "problem" and was wondering if you had the same issue. I'm using Global West, both upper and lower arms. The upper ones don't have a location (or threaded "bung"?) for the brake line bracket to hold the flexible line like the stock arms do. And the lower arms don't have any kind of steering stop like the stock ones do. Did yours come with those "provisions" and, if not, how did you address them?
Old 03-28-2024, 12:35 AM
Arrowsmith's Avatar
Smile
Hi Joe. I have Detroit Speed uppers and lowers in the car. They do not have a provision to clamp the brake hose, but when I built the car I ran the suspension on both sides through full travel and checked the steering lock to lock at the same time. I’m confident the hoses will not be caught anywhere during suspension travel or when turning.
As far as the steering stops are concerned, I have them, so I can’t comment. Plenty of aftermarket an arms do not have steering stops. My blue Nova didn’t have stops (TRZ a arms). The guy who bought it is still delighted with the entire car, so you can take it from there .
Good luck with the build and if you have any questions, fire away. I’ll answer if I can.
The Following User Says Thank You to Arrowsmith For This Useful Post:
'69Novajoe (04-02-2024)
  #160
Old 04-02-2024, 02:24 AM
'69Novajoe's Avatar
Question
Hi Wayne, just thought of another question. I will probably be buying some new rear axles and will also be needing longer wheel lug studs, since now there are no threads coming through the stock lug nuts!! I know they come in all different lengths but I didn't want to get them too long because I'm concerned they might hit the hub caps!! I'm going with the stock caps just like you have. So, my question is, what length studs did you go with?
Thanks again for all your help!
Joe
