Ideas for valve cover to booster clearance?
20180304_172338 by Paul Tholey, on Flickr
I am probably overdue on a post of this particular project- my youngest sister's 1969 Nova- but that will be for another day. We're running an L-88 themed build, but have a Crane stud girdle. That requires a valve cover spacer, and then with the power brakes- the Mickey Thompson and Ansen covers hit. As a temporary solution, the tin cover works with a double stacked gasket. I would love if anyone can share ways these old valve covers have been modified or - pics are even better. Here is little video (forgive the poor audio quality) from this weekend. Plug wires need to be shortened up, etc but should help show what I'm talking about. Yes, that is an Eric Jackson prepared 950 3 BBL carb! https://youtu.be/4ArZVBv9rrE Last edited by PxTx; 03-13-2018 at 03:24 AM. |
FWIW Paul, have you considered going with shaft rockers to eliminate the stud girdle? I built a 565 a few years back and wanted to run the short Ansen covers w/o spacers, so I turned to Crower and a set of their stainless shaft rockers which fit with a low profile. Here's a few pics of them and the short covers I used. They sure keep the valve train stable while allowing the elimination of spacers and girdles. Just a thought?
I like solid lifter cars, big cams and cars w/ 3 pedals in them. Last edited by NorCam; 03-13-2018 at 12:41 PM. |
We probably should have run some shaft rocker. This is an old project, and I've learned that lesson since we started it. I know I can use the tin valve covers as a template for how to modify some aluminum ones and that will be what we do for now.
I was curious to see if anyone had pics of someone else doing this. Ideally some old pics or a set of modified valve covers they had hanging around. Big picture, I'll probably end up having just as many valve coves and we will hoods and wheels for this car- so we can change things based on the theme for the week. I appreciate the suggestion though! |
You could give these taller cheater valve covers a try: https://rover.ebay.com/rover/0/0/0?m...2F332288601954.
1962 Biscayne O-21669 MKIV/M-22 1962 Bel Air Sport Coupe 409/1,000 |
If it's a solid, flat tappet camshaft I'd lose the stud girdle altogether. I really hate those things and like to avoid them. Shaft rockers are awesome but very pricey especially after an investment has already been made into regular roller rockers, studs, guideplates, pushrods, etc. I'm also a fan of taking a bottoming tap into every rocker stud boss in order to install longer studs into the head so they are rooted as deep as possible. ARP has a stud for this if you hit up their catalog.
Mark, I appreciate the though and suggestion. That is the direction I started. If you can see the picture, the tin cover IS one of those taller stock looking jobs. Any I may run that (throw the matching one on the other side) and a decal or two to keep the project going.
Long term, I would like to run the Mickey Thompson covers or Ansen- so we'll see. Since these are early L-88 heads (392) we did upgrade to the longer studs, running SS Crower rockers with a decent roller. We did have to repair the boss on one of the studs, and for that reason, the stud girdle was used. A shaft system would have been nice, but that is hindsight. |
There are a few things you can do.
LOSE the studle girdle. My 074's with those rockers seem to work well for me. We tapped them deeper, cryro'ed the heads and vac sealed as well. Roller cam in the 725 range and make 785Hp @ 7200. I run the 3/4" cheater valve cover as well. Seeing as it's not ment as a stock build with headers showing, lose the large booster for a smaller aftermarket one.
'58 Apache pick up restomodding with twin turbo 522 '78 Z28 4sp being restored '78 Z28 32,000 survivor, Og Yellow paint, AC. '70 W30 convert TRIBUTE '70 CANADIAN Nova SS396 L78 Pro Street '69 CANADIAN Nova SS 396/350 hp '67 CANADIAN Nova SS 427 10 sec. driver '66 CANADIAN Nova SS Race Car '69 FIREBIRD Tubbed Racecar '61 CANADIAN Pontiac Bubble top 409+/4sp (SOLD) '31 ALL STEEL Chevy P.U. GONE (EX-WIFES NOW) |
Or... manual brakes... no booster... no vacuum concerns.
Never had an issue with manual disc/drum or disc/disc combo. Gary
68 Acadian SS-350 auto/AC driver 70 Nova SS-396/375HP Bench Stick 72 Nova SS-350 5sp Mini Tubbed 67 Chevelle Conv. SS-427 clone 70 Chevelle SS-454 LS-5 M-22 |
Redrill the holes where the booster mounts 1 inch raising the booster that amount. Check hood clearance 1st. The lower hole I would fab a plate that would slide over the top studs, put a couple of flat washers and the plate would act as a clamp over all 4 studs.
69 SS/RS 396 M20 X22 Nor 12B,72B,712 bought 1979 FULL OWNER HISTORY 69 Dick Harrell tribute Day II 427 M20 4.10 X11 76 orig pnt, 711 67 Super Stock 302 Camaro re-creation |
