Old 09-14-2018, 06:59 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Hmm what could that be on the '69 Ohio plate.........?
Tim in NSW, Australia
Old 09-14-2018, 09:56 PM
bbbentley's Avatar
Not only are these BBengine frame mounts, but assembly line pieces, thanks, Scott P.(spookster). Posi unit and cover arrived (had them stored at Mom's). Before and After drum to disc ( I know, not the right MC, but I’m using what’s lying around the place. All parts are assembly line pieces! Nothing out of a catalog, except emblem. Last, emblem mounted.
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
HawkX66 (12-18-2018)
  #63
Old 09-15-2018, 01:06 AM
R68GTO R68GTO is offline
Looking great Bentley - it's going to be awesome!
Old 09-30-2018, 10:41 PM
bbbentley's Avatar
"Ratty" has undergone all of it's engine compartment mods. The engine compartment was important, because, now, the engine can go in place. I wanted all the room to install the needed components and , hopefully, ease the procedure. The engine has to go in place so there is enough weight to compress the BB springs, when the spindles are changed. Makes sense. Then all the rest of the suspension can be changed. Then I will turn my attention back to the engine to finish that up and then, the interior and some body touch up paint.
The heater box was a royal pain. The old cover had a rust hole from decades of being a rodent condo. The fan was seized and the squirrel cage gnawed. That required pulling loose the Rt. fender and replacing all that stuff, ugh!
To date, the engine bay has gotten it"s BB fan shroud top bracket, muncie speedo cable, J52 brake setup, BB heater assembly(even have the correct rubber block off piece for the unused tube holes), ZL2 wiring, BB frame stands, correct speedo plug in existing firewall hole.
The funnel is on the fuel line. I soaked it in Evaporust to make sure it was clean.
FULL OWNER HISTORY
The Following 5 Users Say Thank You to bbbentley For This Useful Post:
big gear head (09-30-2018), HawkX66 (12-18-2018), JBALL (10-01-2018), R68GTO (10-01-2018), ZLP955 (10-01-2018)
  #65
Old 10-01-2018, 02:03 AM
Yeah baby....lovin’ it!!!
Old 10-01-2018, 08:50 AM
ZLP955's Avatar
Looking good Bentley!
Old 10-01-2018, 02:07 PM
Thanks for sharing. Its looking great.
Jason
Old 10-01-2018, 02:10 PM
Bentley - you might want to check for your emergency brake operation - could be disconnected! ;>))
Old 10-01-2018, 04:56 PM
bbbentley's Avatar
Details,details...who needs to stop? The car is made to GO! Lol
FULL OWNER HISTORY
mockingbird812 (10-23-2018)
  #70
Old 10-01-2018, 05:26 PM
A12pilot's Avatar
A12pilot A12pilot is offline
Originally Posted by bbbentley View Post
... the squirrel cage gnawed..
Um, yeah. That's what squirrels do!! Man.. so dramatic!
Looking good Bentley!! Nice progress!
Cheers
Dave
