Old 06-17-2018, 03:08 AM
scuncio scuncio is offline
Default Cool Hi-Po '70 Olds
Sure, it's a Delta 88, but I love that it was ordered with the hi-compression 455, front and rear HD suspension, limited slip diff, HD cooling and trans cooler, etc.
Can't remember the last time I saw a '70 full-size Olds that wasn't a 4-door.
Link to 1970 Delta 88 auction
Old 06-17-2018, 03:39 AM
marxjunk marxjunk is offline
i have a friend in ST Louis with a white one...hit in the front..i went over and helped straighten the frame on it..loaded up about the same way..he decided to save it, instead of pinching the drive train and parting it..
Mark
Old 06-17-2018, 04:29 AM
daverd daverd is offline
Great olds I wish I had the room for it..
2013 Silverado
2017 impala
1970 Raylle 350 post coupe
1971 442 W 30 holiday coupe
Old 06-17-2018, 12:39 PM
njsteve njsteve is offline
What is the power output? Is it the same as a W30 engine?
Old 06-17-2018, 01:16 PM
its not a W30...it W30 like though...it is 390 HP..but its a big car..so rated diff than an A-body..you know the game
more like a standard 455 in a 442..big valved heads and a better camshaft..uses E heads instead of F..and a better carb jetting etc...true HP dual exhaust manifolds..its 10 horses less than a Toronado GT (W34)..but has the W33 better exhaust..because the Toro is the flagship...like Vette VS Camaro...
its a cop car...like an interceptor..or a hot turnpike cruiser
theres a huge following..and there a code for it.. B07..and they made way more than the guy is insinuating..most 4 doors..they lose their identity without paper work
Mark
Old 06-17-2018, 01:54 PM
R68GTO R68GTO is offline
I'm surprised there's not a trailer hitch bolted to the car. Usually that's what prompted folks to "order up" on the HP - they had something to pull around.
Old 06-17-2018, 02:09 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Interesting that there are no 455 emblems anywhere. Have they been removed?
Old 06-17-2018, 02:38 PM
ive seen a few cars in person..and ive never seen any on any of them..
except i saw a 455 emb in a grill...not sure it was correct..
Mark
