Old 09-29-2017, 09:48 PM
----You east of the border guys are all right! I don't care what anyone says......Bill S
Old 10-02-2017, 11:27 AM
JpMotorsports JpMotorsports is offline
Send a message via Yahoo to JpMotorsports
----Met you over at Stahls one cruise night. I was Ryans friend. Are you going to be out at the Gratiot cruise this Saturday? If so look for my gold 67 El Camino. Not sure where Ill be but there somewhere.......Bill S
I missed the cruise. Went down to Lansing to pick up my new intake manifold for the Chevelle. Cant wait to put it on!
1982 Pontiac Grand Prix- Dove Gray (Turbo LS swap in the works!)
1967 Chevelle SS396- Tuxedo Black- SOLD
1972 Oldsmobile 442 W29 Convertible- Sunfire Yellow- SOLD
1969 Chevrolet Chevelle/Malibu- Dover White- SOLD
1986 Oldsmobile Cutlass Supreme- Silver- SOLD
1987 Chevrolet Monte Carlo SS- Maroon- STOLEN
Old 10-13-2017, 05:37 PM
Picked up a new Edelbrock Performer RPM intake manifold for the car a few weeks back. Cant wait to put it on in the spring!
Old 10-16-2017, 05:04 PM
1 year ago today I purchased this car. Its been a great year. Lots of little hurdles with this car but shes coming together now.
Old 12-19-2017, 01:36 PM
I want to swap out the 3.23 rear gear. What do you all recommend be the best gear for it??? Mild built 396 TH350 (I know I need a TH400) w/ 2800 Stall 10 bolt rear end (I need a 12 bolt)
Old 12-19-2017, 02:05 PM
What do you want to do with the car? The right gear ratio depends on the use of the car. If you have a 8.2 10 bolt then the factory ratio would be 3.36, not 3.23. The 3.23 and 3.42 are 8.5 10 bolt ratios. Someone could have swapped a '71-'72 Cutlass or Skylark 8.5 into your car, so you need to know what rear end you have.
The TH350 can be built plenty strong for the 396. No need for a TH400. Just replace the 2nd gear drum and sprag and a few other parts and you have a very strong TH350 that will be quicker than the TH400, and you don't have to change the cross member and drive shaft.
A 12 bolt would be nice if you have the money. The '67 Chevelle 12 bolt is one of the highest priced 12 bolt rear ends right now. They were a one year only rear end and kind of hard to find. If you are not worried about it being an original rear end then the Moser rear ends are stronger than the Chevy rear ends and you can order it any way you want.
Old 12-19-2017, 05:48 PM
I never took the cover off to verify but when I bought the car the owner said it was a 3.23 From the pics I have seen for reference it appears to be a 8.2 still has the posi tag on it as well. I want to drive the car still on main roads don't really do any freeway driving. If I am going long distance on the highway I rather trailer it anyways. I have a 8.5 3.73 from my old 72 442 I would use if in fact it was a 8.5
Old 12-19-2017, 06:26 PM
Can you post a picture of the center part of the rear end? Show the cover and the area around the cover.
Old 12-20-2017, 02:34 PM
Here you go. Don't mind it being dirty I need to detail the underside this coming spring.
Old 12-20-2017, 02:46 PM
That is the 8.2 10 bolt. The ratios that are available for that rear end are 2.73, 3.08, 3.36, 3.55, 3.73, 4.10 and 4.56. Which one is right for you depends on how you will drive the car, how the engine is built, what transmission you have and how tall the rear tires are.
If you are going to swap it for a 12 bolt then don't put any money into this rear end. You can locate a 12 bolt and build it or get one from a builder and have it built the way you want it. Any of the A body 12 bolt rear ends will fit your car, but there are some differences in them. The '65 and '66 rear ends have flat spring perches and the spring is held in place with a spring retainer that has a bolt through the center. The '67 to '72 rear ends have a raised center on the spring perch that holds the spring in place. The '65 to '67 rear ends are 60 inches wide over all and the '68 to '72 rear ends are 61 inches wide over all. So the '67 is all by its self with the late spring perch and the early over all width. You will have to use a 12 bolt left upper control arm or modify your 10 bolt arm to fit the 12 bolt.
