Old 06-13-2018, 05:50 PM
auwrestling auwrestling is offline
Default 1972 gto 455 ho 4 spd ww5
1972 GTO WW5 for sale.
Lucerne Blue w/ White top and Interior. 1 of only 310 built with the 455 H.O. and the M22 Rock Crusher. In addition, only 290 of the 635 H.O. cars built in 1972 were ordered with the WW5. That 290 number includes BOTH manuals and automatics. The entire drivetrain is original to this car with the exception of the BLOCK only. It currently has a 2 bolt 455 block But a correct "WM" code short block goes with the car. Everything else is original incl. Heads, Intake, Carb, Unitized Distributor, M22 RockCrusher and 12-bolt 3:55 axle. Original Ram AIr Pans & Boots are also present.This is a very solid car that deserves a good restoration. There is some repair work needed at fender bottoms and lower rear qtrs. right behind wheels. Not too much rust in these areas but it is present. Floors, Rockers, Doors, Window surrounds etc are ALL solid.
Hood IS bent unfortunately. Deck lid had holes from prior owner mounting a wing.
Car Runs And drives
This is a very RARE car in a very desirable color (Lucerne Blue).
$28,900. Call or text 716-536-2047
Old 06-13-2018, 06:28 PM
markjohnson's Avatar
I wear a Bowtie and was totally unfamiliar with WW5 GTO's until I just Googled it. Pretty cool that there was a single option box that a buyer could check to get all the coolest go-fast for the year!
Old 06-14-2018, 11:29 AM
The Boss's Avatar
The Boss The Boss is offline
It was the most expensive option ever offered on a GTO.
I have a hood and deck lid if needed Matt.
Some guys they just give up living
And start dying little by little, piece by piece,
Some guys come home from work and wash up,
And go racin' in the street.
Bruce Springsteen - Racing In The Street - 1978
The Following User Says Thank You to The Boss For This Useful Post:
69rbadaz (06-14-2018)
Old 06-15-2018, 12:21 AM
Ok I’ll note that
Old 06-15-2018, 01:32 AM
daverd daverd is offline
Any pictures of this WW5 ?
2013 Silverado
2017 impala
1970 Raylle 350 post coupe
1971 442 W 30 holiday coupe
Old 06-15-2018, 11:17 AM
Pm or text me your info for pics.
