Old 05-11-2018, 11:27 PM
bbbentley's Avatar
Originally Posted by VintageMusclecar View Post
Back to square one, still looking.
Maybe you could have said that it was not the backspacing you were looking for. You insinuate that I was unwilling to help or try and help or others may take it that way and that was not the case.
FULL OWNER HISTORY
Old 05-12-2018, 02:23 AM
Do you still have a set of 3 1/2s or are you still looking for those too?
https://louisville.craigslist.org/wt...569830155.html
https://stlouis.craigslist.org/wto/d...556222495.html
Old 05-12-2018, 02:58 AM
VintageMusclecar's Avatar
I wasn't insinuating anything, sorry if you mistook it that way.
As I said in my original post, I need the 8.5" rears with 4 7/8" backspacing, and as I replied to your text message your wheels are the shallow backspacing.
For the record, I had no issue with you.
Old 05-12-2018, 03:38 AM
Lynn;
For whatever reason, my 8's were only about an inch away from the lower shock mounts, I don't think I could get anything wider than 9" on there without it hitting.
I figured it might be a bit tighter on the 67. These 15 x 10 are tight on my 68 for sure.
Will keep my eyes peeled. Good luck on your search. There are out there. Sometimes you just have to be patient.
Old 05-14-2018, 09:02 PM
Here is another set of 3 1/2s.
https://bgky.craigslist.org/wto/d/sk...587679715.html
Old 05-15-2018, 07:06 AM
markjohnson's Avatar
Originally Posted by Lynn View Post
If you go with Centerlines, do yourself a huge favor and have some hubcentric rings made. I don't believe anyone has them on the shelf. I can send you the specs, or you can just measure them yourself. Several places on line that will make them for you.
I had several guys ask if I have to re-torque lugs from time to time, because most guys running CL wheels do have to re-torque. I do not, but only because I had rings made for both sets that I run. The very early CL wheels used beveled lug nuts (I STILL had rings made for those) but all the later wheels use a shank type lug nut. There is no way that the wheel is exactly centered via those shank nuts without a ring.
I'm also a big proponent of hubcentric rings and have made several sets in the past. The weight of the car should be on the axle register and not the studs. It's amazing how large that gap can be between the axle register and some aftermarket wheel manufacturers!
Old 05-15-2018, 12:01 PM
Unfortunately there's no usable hub for the wheels to register on. These Strange axles have a very shallow hub that's only long enough to register the brake drum.
On the plus side, the axle studs are 1/2".
Old 05-21-2018, 08:33 PM
Still not exactly what you're looking for, but closer. https://www.ebay.com/itm/mickey-thom...8AAOSwhcdakLNC
Old 06-14-2018, 04:23 PM
The Hot Rod Reunion is in Bowling Green KY this weekend. The swap meet is always pretty good, and usually several sets of Centerline wheels. If you are still looking I'll let you know if I find something.
Old 06-14-2018, 11:13 PM
Thanks for the offer, but I'm putting the search on the back burner for now.
