-   -   67 Camaro Data Tag Question (https://www.yenko.net/forum/showthread.php?t=101079)
67BobcatGTO 10-07-2008 12:10 AM
Found a 67 RS/SS Convertible. All original paint, untouched car. The car was built in Norwood. The data tag is painted white in color... Why? Anyone else see this.
69RSZ 10-07-2008 12:53 AM
Re: 67 Camaro Data Tag Question
It was sprayed white so the people on the line could read or see the options more clearly.here is one such tag sprayed white.
http://i96.photobucket.com/albums/l1...rewer1/007.jpg
Xplantdad 10-07-2008 06:43 AM
I remember Charley talking about original white painted trim tags...
firstgenaddict 10-07-2008 08:24 AM
I've only seen it on 67's
67BobcatGTO 10-09-2008 05:31 AM
Thanks! That's great info.
Mark_C 10-09-2008 02:45 PM
The tag was obviously sprayed white after the firewall blackout was applied, which means it was either painted as it left the Fisher Paint shop, or at some later point in the assembly process. Not every car had their tag painted so it can't be for better visibility, unless some tags were magically easier to read than others. It may even have been done by GM as it came thru the wall from Fisher to flag the car for some reason. No one really looked at the tag, since there was paperwork similar to GMs body broadcast sheet hanging off the firewall with Fishers version of equipment codes on it
rd67RSSS 10-09-2008 09:00 PM
Bob,
Would that 67 RS/SS Convertible with the white tag be a pace car?
We're talking about this exact same topic the last few weeks over at www.camaropacecars.com
Kurt S 10-09-2008 09:58 PM
I've seen original paint 67's with white tags and without white tags.
It was obviously done to indicate something. Seems strange if it was to highlight the tag cause the tag info was also on the UOIT. Also interesting cause there were other ways in the system to flag things and the blackout paint was specifically there by Marketing request to cover assembly plant markings. I've never observed a pattern to it, but the sample size is small since most firewalls have been repainted over the years. Never seen it on a 68 or 69.
I'd say that it was for Fisher since the tag and it's info was for Fisher (and it would seem strange for Chevy to be marking a Fisher item). Since it was done after firewall blackout, that indicates that it probably was for the Trim Shop Operations in Fisher.
L78M22Rag 10-09-2008 10:28 PM
Sounds like a neat car! Got any pics of the car? https://www.yenko.net/ubbthreads/imag...-I-Have-It.gif
Mark_C 10-10-2008 01:28 AM
I was thinking maybe GM did it at the entrance to the body bank to indicate that the car should be sent to one particular line of the body bank vs. another. Maybe all the cars with the white tag went into one of the three lines that went straight thru the body bank and out onto the assembly line, or vice versa it indicated they would go to one of the other lines that needed to be metered into the assembly line because there was extra work needed, RS, A/C or something like that. Fisher was almost done with the car by the time it cleared the paint booth, about the only thing left was interior installation so unless it was being used to call out a deluxe interior vs a standard, or interior trim option there really wouldn't be a need to mark the car like that, and the UOIT would handle that just like it did for the previous operations.
