-   -   69 Camaro sway bar retaining band rubbers (https://www.yenko.net/forum/showthread.php?t=129164)
Day2_69Z 09-26-2014 12:25 AM
Camaro sway bar retainer rubbers,,,, does anyone offer these ? Or a member have a pair to sell/trade ????
These are the rubber biscuits under the circle clamps than keep the front sway bar from moving left & right.
I never see these on eBay nor in any Camaro catalog.
m22mike 09-26-2014 11:54 AM
Re: 69 Camaro sway bar retaining band rubbers
I have never seen them offered in the aftermarket. I would ask in the parts wanted section ?
Mike
CamarosRus 09-26-2014 10:41 PM
What diameter is that sway bar ?
There is a nastyz28 member that has reproduced the rubber bushings for
9/16" rear 70+ Camaro sway bars.
Lynn 09-27-2014 02:57 AM
69 Camaro front is 11/16, except for copo with sports car conversion, which is 13/16.
BTW, I fixed Tom up with a set.
CamarosRus 06-10-2020 08:15 PM
I have the original front sway bar removed from the #27 Alan Green ZL-1.
I also have 6 New Rubber "Bands" (as written above) and Two Original "Used"
Metal Clamps (No Fasteners)
Can You suggest a Value ????
bbjohnny 06-10-2020 09:29 PM
What was the application? Did all 69 Camaro's use these? Has anyone seen a set used on a 13/16" swaybar? Thanks.
CamarosRus 06-20-2020 05:09 AM
to the top
Enoch 06-22-2020 06:55 PM
I have several originals. I always save them
CamarosRus 01-16-2024 04:11 AM
I have 11/16 sway bar rubber bands
1crossram 01-16-2024 07:04 PM
Did the 67's use them as well? I have also seen them on 72 Novas.
