1974 Trans Am 455 SD, Project Car
15 Attachment(s)
1974 Trans am 455 SD, GM of Canada Documented Numbers match car. Red with Black. Auto, A/C. Tilt, PW and more.
This car requires a restoration and engine and transmission are out of the car. All original Drive train including Engine, Transmission and Differential. The numbers matching short block has been rebuilt and is wrapped in plastic. Heads were rebuilt at one time. Original Carb, Intake, Heads, Alternator, EGR valve, Valve covers and more. Distributor is not original, no camshaft, has headers but have a new set of reproduction exhaust manifolds from Ram Air Restorations, These were purchased in 2006. The dash pad has a crack on the passenger side, but the package on the roof in some pictures is a very nice original black dashpad that comes with the car. I am in no way a Pontiac expert, this is the only Pontiac I have ever owned. Reply with questions and I will answer them to the best of my ability. Car is located in Calgary Alberta Canada. $28,500 US. |
NICE! :burnout:
Can we get a picture of the VIN on the block, and the underside and lower panel pictures please.
I'm guessing the car has had one repaint?
If so--- Is there any rust repair in the quarters? Are the frame rails solid? |
I think that is a fair price, distributor is a bummer.
Sd vin , engine vin, trans vin
Here are some pictures of the vehicle Vin on Block and Trans
1974 Super Duty Vin Pictures On Block & Trans
30 Attachment(s)
The Good, The Bad and the Ugly, Here they are, assorted pictures of the Trans Am SD. The car had 1/2 quarter panels installed many years ago, now bubbling around where the filler was towards the rear. 1 repaint.
oK ............ Now that i see some scary rust ..... price may be agressive.
All numbers one of 700 Auto cars. The price is very fair.
body pictures 455 SD
30 Attachment(s)
If that is a lot of nasty rust to you, you should see the cars from eastern Canada. Here are some more pictures.
