69 Z vacuum hose smog Tee
1 Attachment(s)
looking for the 1/8" vacuum T for the smog hose to connect to carb
Looks like the same connector used for the head lamp washers. May have to buy the kit.
http://www.drclassic.com/catalog/Cam...rt/R00067.html |
I've got a couple of originals with the numbers. The headlamp washer kit tee is different on originals.
2 Attachment(s)
The four on the bottom have no part numbers on them, and they are $50 each the three on the top have part numbers two of them have the raised pad with the part number and the other one just has it on the round part. Those are $80 each. If you're interested let me know. Thanks
