1969 427 oil priming
I am trying to prime my 427 solid lifters only getting oil from a few in the back do I have to rotate 90 degrees at a time as I have read to get the rest to start oiling?
I usually rotate as I prime. I don't know if it's required or not.
You will need to rotate in order to get oil up to the top out of all rockers.
Tim |
Yes you do.... |
Thank You for the info
You also need to use either and old-cut down distributor, or a pre-oil tool so that the oil passages connect side to side.
I am using a tool I will try to turn a quarter prime and hopefully see other oiling then keep adding a quarter turn
No I did not but I can tell you I purchased a oil prime tool it was a problem the oil channel is too big it lost oil pressure I made one out of a old distributor now I had to cover the lifters oil is flying out
One more question 2 of the rocker in the back are flowing hard to the point I had to deflect it it pours out no matter were I position the rotation is that normal our is it a defective lifter this is a new set
