69 pinion yoke
1 Attachment(s)
Need a 1969 12-bolt pinion yoke, part number 3954393. It takes straps and bolts, not U-bolts. Sometimes it is called a 4394 or 43-94 because of the 43 and 94 that is cast into it. Thanks!
John |
I might have one. I picked up a yoke yesterday, but not sure which one it is. I'll check later this week.
One thing use should check with a new u joint is side to side play.
These yokes also are on 73 and up chevy trucks also
That's good to know. Thank you!
I rebuild 12 bolt rearends. I have quite a few 68-71 chevelle rearends here
I checked mine last night and it's the U bolt type.
Thank you for looking Freddie. I appreciate it!
Is this for a 69 camaro.
Yes, for a BE rear
