-   -   1967-1970 Camaro NOS GM Race Wires, White String Trunk Weatherstrip, + Upper Bushings (https://www.yenko.net/forum/showthread.php?t=159768)
GRAFFZ 03-01-2020 05:58 AM
10 Attachment(s)
NOS Delco V8 Ignition wire set. Orange High Temp SS-550 stainless steel core wire "cut to fit" set. Stainless steel core ignition wires for Special High Performance racing engines to get the maximum spark at the spark plug.
1967-1970 Camaro Z/28.
*************SOLD****************
NOS GM original design trunk weatherstripping. It is a early production type with the white string. Measures about 14.5" Feet which should be long enough to fit many cars.
The weatherstrip is still soft and flexible, but does have a cut which is mostly in the gutter area. Also has 2 small cuts on the top.
1967-1969 Camaro.
(4) NOS GM upper control arm bushings. Vintage NOS with the extended rubber on the inside. There are 3 different designs here. (2) bushings are embossed with "HARRIS", one with "GOULD" and one is very early unmarked.
1967-1969 Camaro.
1963-1972 Corvette.
1964-1972 Chevelle/Malibu/El Camino.
1968-1972 ChevyII Nova.
Thanks, Sam
