Rally Wheel Paint...
Looking to paint a set of wheels...what is the best choice for spray can rally wheel paint??
thanks, -wilma |
Quote from Jerry MacNeish
Have perfect paint for you. Krylon #1403 dull aluminum. It’s the most perfect version of Argent silver there is. And best yet, it comes in a spray can. Doc. |
Rally Wheel Paint..
O'Reilly's has it...$5.99/can...sounds like a good deal.
Thanks... https://www.oreillyauto.com/detail/b...t/1403/4402588 |
1 Attachment(s)
Ames has the paints and the mask kits.
I've been using Krylon #1403 since 1996, never a problem.....
Eastwood Rally Wheel Paint
Rich |
The best way to get the color rite is get the formula off the paint chips for the year of your car, then go to the automotive paint store, you can get the glass bottle spray bombs, mix your paint/ thinner your self. It’s easy, Then it’s rite on. A lot of the GM car lines had rally’s, if it’s not for say Pontiac double check. GNE here in the D mixed me mine, the guys there will tell you how to mix. I did my jack the same way, they matched the blue, easy.
