-   -   1967-1970 Camaro Z28 NOS GM Brake Master, Advance, Starter Nose, Dipstick, + Belt. (https://www.yenko.net/forum/showthread.php?t=163447)
GRAFFZ 10-05-2020 03:09 AM
1 Attachment(s)
GRAFFZ 10-05-2020 03:11 AM
NOS GM brake master cylinder. Made by GM about 50 years ago.
The front pad is unstamped. It has 1 1/8" bore which is correct for
disc brake models with brake booster. Brand New and never bolted up,
but is missing the cap + bails. Super clean inside.
1967-1968 Camaro.
1967-1968 Chevelle, Malibu, + El Camino.
1968 ChevyII Nova.
1967-1968 Impala, Caprice, Biscayne, + Bel-Air.
1967 Pontiac Firebird.
*************SOLD**************
NOS GM Delco-Remy Distributor vacuum advance. Made by Delco 50+ years
ago. It has the correct assembly line "MS 201 15" stamping. Fits the
1969 Camaro (302) Z/28 1111480 distributor, 1970 Camaro (350) Z/28 1112019,
as well as 1969 Big Block (L34 + L35) (396) 1111497 + 1111498 distributors.
Great patina for being over 50 years old.
1969-1970 Camaro Z/28.
1969 Camaro, Chevelle. + Nova (396) (L34 or L35 only).
NOS GM starter drive nose housing assembly. This is the later design
that GM went to that has a inner seal to keep moisture from getting into
the starter(See 3rd PIC). It fits the 1967 Camaro Z/28 starter(#1107400)
as well as 1968-1969 Camaro Z/28(#1108367).
1967-1969 Camaro Z/28.
NOS GM 302/350 Z/28 engine dipstick. Hard to come by early design that
has the flat rolled loop handle. The GM part# is stamped on the blade
with "USE SE ENGINE OIL". Very nice detail item for your Z28.
1969-1970 Camaro Z/28 (302 + 350).
Listed on eBay starting at $69 and closes on Tuesday night.
EBay link: https://www.ebay.com/itm/133536533373
NOS GM power steering drive belt. Correct assembly line cloth wrapped
stamped belt that has the original GM numbers stamped on it. On the
1968 Corvette this is a alternator belt. The stamping are very nice and clear.
Measures 36" length, 3/8” top width.
1968 Camaro Z/28 (302) + (350).
1969 Camaro (327 + 350).
1968-1969 ChevyII Nova (327) (with Special High Performance).
1970 ChevyII Nova (350) (Except A/C).
1968 Corvette (327) (350HP) (First design alternator belt)
(Except air conditioning or power steering).
Listed on eBay starting at $75 and closes on Tuesday night.
EBay link: https://www.ebay.com/itm/133536534018
Thanks, Sam
