The potential of the 1969 ZL-1
Excellent!
Can’t see anything ☹️
560 cubic inches max for BBC, and anything goes on interior engine mods, as long as it breathes out through the cast iron exhaust manifolds and a 2 1/2 inch exhaust system. Otherwise, the class is what it says, Stock Appearing.
Here are the rules. fastdrags.com/fast-rules It gets expensive to run that fast. Vewwy, vewwy expensive. Bring all you got.... and hope you brought enough. |
Ya I believe they also "ALLOW" BBc to use an aftermarket block as the OEM "512" usually "could" get to about 511 to 526 is about the pushing max inch limit.
I do think my ZL1 (475 inch) powered '69 Nova (for now) will push me well passed the 9.50 mark. BUT we have headers and will use slicks and a few other things they don't like in that series. I built the car as a sorta day 1.5 of what "could" be done with mostly factory stuff and a bit of "normal-for-the-times" aftermarket stuff. I never planned to run the series and have a few chats with some of them and go input from Dudek and Carey. As well as the guys at BES that did Lanes stuff. |
1 Attachment(s)
It is amazing how quick they run on the stock size tires.
"Stock appearing" allows more modifications then and "Pure Stock" here is a list of fastest Pure Stocks |
Lots of Mi. Folks!!!
Lotsa 427
wonder what the ET of #22 would be with 456 gears?
What about that L78 at #3!
Mind blown |
