-   -   Installing a new radiator tag (https://www.yenko.net/forum/showthread.php?t=176495)
sixt9rsx33 08-27-2023 12:49 AM
I need to install the above on my 69 Z28. OG one was missing. Do I remove the battery so I can get to it better and just tap the tag in the lip of the radiator or should it also be soldered in there?
Lynn 08-27-2023 12:58 AM
Original was soldered.
I would just keep it in an envelope until the next big service. You could clip it on, but always a chance it pops off. Don't know how often or how hard you drive it.
Obviously not likely to pop off sitting in the garage.
cheveslakr 08-27-2023 02:17 AM
If you want it on there, epoxy it....or do as Lynn said.
sixt9rsx33 08-27-2023 02:12 PM
I drive it about 300 miles a year. Car is pretty much done as far as big repairs left. I will take the battery out so I can get to it well and attach it with a little epoxy. I have had this tag about five years or so. Might as well put it on I suppose.
Thanks guys
Mr.Nickey Nova 08-27-2023 06:31 PM
You could put a little silicone on the back also, that's what I did.
