-   -   Brakes on my 87 El Camino (https://www.yenko.net/forum/showthread.php?t=177103)
enio45 10-25-2023 04:26 AM
I have an original low mileage 87 el camino - 20K miles.
pads, rotors, and all the brake system is orig to the car. I feel like the brakes are spongey - like if i wanted to, I cannot LOCK them up if needed. It will stop, but to a slow roll, not lock up.
I bled the system and flushed out the fluid and installed new fluid. No real change - so im trying to figure out where the issue may be - booster, master, calipers and rear wheel cylinders need cleaned out and redone. Not sure best way to separate the diagnostics to pin point he issue, or am I at a trail and error?
Any advise? I have no leaks in the system, just a soft feel to the brake pressure.
thanks in advance.
RPOLS3 10-25-2023 01:14 PM
When you bled the system did you get a good stream of fluid? If the proportioning valve has failed or is not working properly you may not be getting enough fluid to the front or rear.
enio45 10-25-2023 02:33 PM
yep we had an issue with the rear - had to force some fluid thru when we opened the bleeder - i was using a suction tool to bleed the brakers thru the calipers. at first nothing then applied some brake pressure and a big stream came out........i can't say it was nice solid stream.......maybe look into the prop valve? R&R clean, rebuild - they rebuildable?
RPOLS3 10-25-2023 02:48 PM
I think the 1987's were similar/same to the earlier 1970's GM cast iron units and yes they are rebuildable by any of the typical places for calipers/wheel cylinders. The valve may be stuck due to rusty fluid/varnishing and not allowing enough fluid through.
enio45 10-25-2023 02:50 PM
ok will look into this today! appreciate the thoughts and guidance.
olredalert 10-25-2023 04:25 PM
----Along with what Jake said, I would replace the pads. They may be glazed and certainly are old. Possibly have the rotors fly cut to give the new pads a good brake in surface.....Bill S
PeteLeathersac 10-25-2023 08:51 PM
All above plus pull frt. calipers and service slide systems also remove drums and confirm rear wheel cylinders Ok both directions + adjusters free and wound out as far as possible but you can still get drums on/off.
Next, elevate rear and bleed system, RR first on to LR and RF w/ LF last also if weak pressure bleeding, consider flex lines may be internally collapsed whether they look good externally including rear flex if low/no pressure @ wh. cyls.
Best of luck!
:beers:
67since67 10-25-2023 09:48 PM
Best of luck!
:beers:
This is great advise!! :biggthumpup: - Bill W
John Brown 10-25-2023 11:54 PM
Rebuild kits. https://www.musclecarresearch.com/
enio45 10-26-2023 04:50 AM
Sounds like a good brake overhaul would be best approach......one can spend alot of time on one item or another, hoping to identify the issue etc.
Comprehensive brake overall might be in order - new rubber lines all the way around - new proportioning valve, pull and rebuild all brake calipers - fit and rears......
flush and clean system - see what we have.
i was trying to avail this level of effort, but all the points / suggestions above drive me to think this is the best approach. related to the booster and master cylinder - maybe a rebuild of the master is in order - i have good boost from the booster - so that will be the only think i dont touch.
sounds??????????
