Old 09-30-2011, 06:23 AM
CUSTOMD2 CUSTOMD2 is offline
Default REAR END AND TRANS HELP
COULD ANY BODY DECODE WHAT THESE ARE OUT OF .
12 BOLT REAR END......#C BS 0508G1
TRANS 4 SPEED #s 392566 SIDE
3952659WA TAG
3952648 DR SIDE
385756-GM TAIL
POD13A
THANKS FOR ANY HELP IN ADVANCE
Old 10-02-2011, 03:12 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Re: REAR END AND TRANS HELP
well, they are 1970 and up units as signified by the extra 'C' before the BS (but possibly very late '69) and the '0' after the P on your Muncie - find the VIN on the trans casing and post it - should run up the side in small type on the maincase or be stamped on the very top of the box
it's a3.31 gear ratio rearend and an M-20 Muncie
leaf spring perches? or coils? drum-to-drum width?
Old 10-02-2011, 03:49 PM
Tracker1's Avatar
your rearend is probably out of a Nova. That's the only model I can find the 'C BS' code applied to...
Old 10-02-2011, 10:34 PM
LAST NUMBER ON THE TRANS CASE;
10K191835
THESES ARE BOTH IN A 70 NOVA I JUST BOUGHT,SS 396 CAR.
WANTED TO MAKE SURE THE REAR WAS THE ORIGINAL TO THE CAR,THE TRANS CAME WITH THE CAR AND WASNT SURE IF IT WAS THE ONE THAT ALLSO CAME OE IN THE CAR.
ANYBODY KNOW WHAT THE ZJ6 IN THE COPO BOX ON THE BUILD SHEET MEANS?
ALL I COULD FIND ON THE NET WAS ...SPECIAL SPORT SEDAN.
Old 10-02-2011, 10:57 PM
Tracker1's Avatar
so are the last six digits of your Nova's VIN 191835?
Old 10-06-2011, 03:33 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CUSTOMD2</div><div class="ubbcode-body">ANYBODY KNOW WHAT THE ZJ6 IN THE COPO BOX ON THE BUILD SHEET MEANS?</div></div>
Fisher Body Broadcast Sheet ZJ6 = SS Nova Trim. Ignore the COPO header, that box was just overflow for the RPOs.
Greg
Old 10-02-2011, 11:16 PM
Fast67VelleN2O's Avatar
K is a Kansas City vin isn't it? Novas weren't made there.
Day 2 is Life.
Old 10-03-2011, 11:55 PM
True &amp; true.
