Old 08-17-2015, 10:04 PM
danachevroletfor1967 danachevroletfor1967 is offline
Default Trying to Decide Value of my 1969 Z/28
After much work and effort I have been told by my mechanic that my '69 Z needs a complete engine rebuild. There is too much exhaust smoke, oil getting into the intake runners, and the engine cannot hold vacuum at idle, it dies. Distributor has been gone thru, new valve seals, carb work, and intake manifold resealed. No external vacuum leaks can be found. Car has 80,000 miles on original engine that nothing has ever been done to, as far as I know. I can't afford a complete engine rebuild so have decided to sell it. I've owned it for 19 years and maybe it is time to pass it on to someone else to enjoy. I know what I would ask if the engine was fine but have no idea about the value knowing the engine needs to be rebuilt.
Here are some details on the car:
Original engine and rear end, trans is not original.
All sheet metal is original as far as I know.
Car was repainted in original Fathom Green more than 20 years ago. Paint is still excellent.
I have original Protect-o-Plate and Chassis Broadcast copy and owner's manual, along with pictures of the car when it was only 2 months old from the original owner.
Original black and gold California license plates. Period correct, although not original to car, dealership license plate frames.
First aid kit from dealership.
Five correct date coded YH wheels and 5 reproduction E-70-15 Goodyear Wide Tread GT tires.
Interior is in great shape.
Everything works except clock, fan blower motor, low fuel indicator light, and headlight washers (it is a Rally Sport also).
I also have that would be included with the car:
new OEM style restoration radiator and mounting hardware, new Holley 4053 DZ carb, and new OER fan shroud and mounting hardware.
How much might my car be worth? I know it is hard to come up with a value without seeing the actual car, but I would appreciate any help you guys could give me. I am going to try to add some pics with this post if I can decipher how. Thanks again guys.
Old 08-17-2015, 10:55 PM
Default Re: Trying to Decide Value of my 1969 Z/28
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: danachevroletfor1967</div><div class="ubbcode-body">There is too much exhaust smoke, oil getting into the intake runners</div></div>
Huh??? AFAIK, the only way oil can get into the intake runners is if there's a blown intake gasket or a cracked intake manifold. That could also cause a lack of vacuum and engine dying. I think I'd be seeking another opinion from a different mechanic.....don't give up on the old Z just yet. Beautiful car!
Bill Pritchard
Old 08-17-2015, 10:56 PM
scuncio scuncio is online now
Beautiful car. I know you've heard this already but you would really do yourself a disservice by selling such a nice car needing an engine rebuild. The typical high dollar collector won't want to deal with the engine rebuild so you're limiting your market pretty significantly. I'll say the car is worth $15k less on the open market needing the engine rebuild.
Old 08-17-2015, 10:57 PM
And I agree with Bill, get a second opinion before you throw in the towel on the engine.
Old 08-17-2015, 11:23 PM
GMC_Typhoon GMC_Typhoon is offline
Just rebuild the engine?
Old 08-18-2015, 12:43 AM
njsteve njsteve is offline
The problem you describe is exactly what just occurred with a friend of mine's 1970 Challenger R/T 440. It turned out that there was a crack in the intake manifold on the valley side that was invisible to anyone outside the engine. When the car warmed up, it ran like crap. After swapping carbs multiple times, he finally pulled the engine and that's when they discovered the crack on the underside of the intake. It caused a major internal vacuum leak that sucked the oil from inside the lifter valley into the lower runners of the intake.
Before letting go of the car I'd swap intakes out and see if that fixes it.
Otherwise my 14 year old and I would be happy to rebuild that engine. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 08-18-2015, 08:09 PM
Thanks for your input guys. You've made me think twice about my first plans and think more about keeping her. I know I would probably feel bad and kick myself if I did sell her. I do have another question; it may sound stupid to more mechanically inclined guys than myself but I honestly don't know the answer. How do you know when or if your car needs an engine rebuild? Mine does not use any oil where I have to add any between changes. It doesn't produce blue exhaust, black or gray, yes, but no blue. It runs great and is not down on power that I can notice. It just wants to die every time I slow down to a stop. Are there different levels of engine rebuild, such as just needing new rings, or a new cam and lifters, and not always needing complete machine work such as reboring, decking, etc.? I read that the compression in a 302 should be 190 per cylinder. Mine has between 160-170 in each one. Good or bad? No problem or too low for such a high compression engine? Thanks again for your input.
Old 08-18-2015, 08:38 PM
My diagnosis is you need a new mechanic. If the engine has an erratic vacuum signal you could have a vacuum leak somewhere. An intake valve being to tight will also cause this symptom since it will produce a vacuum leak to the intake which will cause 4 cylinder to be effected on a dual plane intake and all 8 on a single plane. Silly question, has the PCV valve been replaced? It sounds like you need to start with the basics like a compression or leakdown test. Also, finding the source of the oil getting into the intake may point you in the right direction.
I hope you can get it sorted out.
Jason
Old 08-19-2015, 03:01 AM
Try rebuilding the carb. Contact Eric Jackson on this Site for help.
Old 08-19-2015, 11:59 AM
I agree find a new mechanic. My friend had a similar problem on his 67 Vette small block, and it ended up being that the intake manifold was not torqued down on the engine. I agree with Super Nova SS, start with the simple stuff and work from there.
Regarding your compression in each cylinder, I would think given your engine had 80K miles on it and all the cylinders are within 10 pounds of each other you are fine. But I am not an engine rebuilder.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
