Old 06-25-2024, 05:49 PM
Default Replacement for 1969 Starter Solenoid
Is there a aftermarket starter solenoid that "looks' very close
to Delco Originals......
I'm in process of restoring a 9 K 22 Delco Starter and need
a NEW appearing Solenoid !!!!!!!!!!!
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Attachments - The Supercar Registry IMG_3272.jpg IMG_3251.jpg IMG_3094.jpg IMG_3091.jpg
Old 06-25-2024, 06:08 PM
BCreekDave BCreekDave is online now
Depends on what "looks" means. None that I know of that have the Delco Remy solenoid marks
Owned since 1978 - First Car
Old 06-25-2024, 08:22 PM
I understand and agree with your point Dave...........
As hard as they are too SEE when installed in the car
is there a particular aftermarket brand that "LOOKS"
Ok ????
Chuck Sharin
[email protected]
Old 06-27-2024, 04:17 PM
Zman1969 Zman1969 is offline
Chuck my new go to is Napa
https://www.napaonline.com/en/p/MPEST124SB
https://www.napaonline.com/en/p/ECHS...pid=MPEST124SB
last 2 are Echlin which IMO are good quality
Also on RockAuto has Standard Motor products
https://www.rockauto.com/en/moreinfo...pt=4188&jsn=11
and
https://www.rockauto.com/en/moreinfo...&pt=4188&jsn=8
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 06-27-2024, 05:59 PM
169indy's Avatar
169indy 169indy is offline
I have had limited success grafting a Old DELCO cap to a replacement Coil body. It gets a little tricky given different mounting molded back sides and contact matching, but I can be done to gain a fresh wound core with a original looking nose.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 06-27-2024, 07:25 PM
John Brown's Avatar
D969 solenoid 1114356 was the Delco Remy/GM replacement number, but I'm all out of them. 12bolt_tom on ebay bought the last of the Studebaker International inventory that fit Chevrolet engines used in 65 and 66 Studebakers they had in their inventory at the South Bend location. I know for a fact they had some open box/out of the box nos solenoids, because I bought all of the still unopened ones they had. You might try contacting 12bolt_tom.
ebay.com/12bolt_tom
John Brown
Old 06-27-2024, 07:37 PM
Were assembly line solenoids black or zinc plated? Seems like I've seen both.
Old 06-27-2024, 07:46 PM
X66 714's Avatar
X66 714 X66 714 is offline
1969 big block the entire starter was black including solenoid & cast iron nose.....Joe
BCreekDave (06-27-2024)
Old 06-27-2024, 07:59 PM
Thought so in 70 too.
Old 06-27-2024, 08:50 PM
X66 714's Avatar
I don't know 70's but you're probably correct. I can only state what I know is fact.....Joe
