BE rearend pinion flange part number
Can someone tell me the correct part number for a BE rearend pinion flange. I have been told the 9210 flange (p/n 3879208) is correct but cannot find it in my parts book.
Steve
Steve 67 Z-28 69 COPO Camaro |
3954393, from the Aug 1971 P & A manual. BE was not different. I'm sure one of the aftermarket drive train suppliers carries it under the Eaton #.
Thanks. My 75 P&A manual has the new number 3996118. I need to find a 69 or 70 P&A.
It says that 67 Camaro 12 bolts uses 3879208, same as the LS-6 12 bolts. Steve
From my personal Library if it Helps..
That helps a lot.
Looks like the 4393 used a 1310 u-joint and the 9208 used a 1330 u-joint. Wonder why the 67 12 bolt used the 9208 ant the 69 used the 4393. Steve
