Does anyone have the the actual specs. ie- lift and duration for a stock camshaft in a 396/350HP motor out of the factory??
Thanks SYC....... Rich ![]()
"This is Sheriff Buford T. Justice, I'm in pursuit of a black Trans Am, he is all mine so stay out of the way" |
'67 # 3883986
Intake opens 56deg BTC INtake closes 114deg ABC Int. Lift: .462 Int. Duration: 350deg Exh opens 110deg BBC Exh closes 62deg ATC Exh lift: .480 Exh duration: 352deg Overlap: 118deg Verne ![]() PS: This the same cam that was used in the '67 427/390hp motor. |
Thanks Verne........ Any idea if this was the same specs used through the late 60s, namely 1969??? I'm willing to bet it was....
Rich
Rich,
All my books and references pretty well peter out after '67. sorry. Perhaps someone with later parts books can find out whether the same part number was used through '69. Verne |
That is the same Cam they used in the 1969 L-34 396/350 HP,up until the new 402's came out later on,then they switched over to the #4359.
Thanks Guys....
Rich
