Can anyone tell me what the significance was/is of the three
colors seen on many NOS SHP parts? I'm referring to the white, green, and purple colors seen on many rods, cranks, blocks, etc... Nuch
I believe that the workers would make a mark when their process was done. Either that or to identify certain parts.
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
When parts left a certain dept. the end packout guy or last man put a dab of paint to show he checked it before it left. The colors differed by shift, days may use purple and afternoons may have used yellow.
A lot of times marks were made to show a part had been thru a process already. And certain models of parts get dabs to quickly I.D. them. |
not exactly ...
the parts are color coded by application ie "pink" rods, those were the special performance ones the colors differentiated the applications, ie HD, performance, passenger, etc When I worked at Pontiac in the very early 70's all the "good" stuff carried purple dabs
Jim R Scottsdale, AZ ![]() |
not exactly ... the parts are color coded by application ie "pink" rods, those were the special performance ones the colors differentiated the applications, ie HD, performance, passenger, etc When I worked at Pontiac in the very early 70's all the "good" stuff carried purple dabs [/ QUOTE ] I think what you just said is what I what myself and the other guy said, certain models got certain colors. I ran packout for many years and each front pump that left the dept had a green mark that I had to put on it. Afternoons used yellow. This is still done today. An automatic transmission will have a ton of paint marks inside it. |
not exactly
a hi-po axle shaft has purple paint on it, the lo-po (is that a word) ones had a different color (can't remember, only remembered the "good" stuff colors), nothing to do with what shift, it was application based, not shift or employee
I know what you are talking about. All the ZL-1 and L-88 stuff has the Purple, Green, White color codes. I saw an NOS hipo big block with these as well. Here is ZL-1(L-88) crank and rod:
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi 1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package. |
I know what you are talking about. All the ZL-1 and L-88 stuff has the Purple, Green, White color codes. I saw an NOS hipo big block with these as well. Here is ZL-1(L-88) crank and rod: ![]() ![]() [/ QUOTE ] This is exactly what I am referring to. So were the colors shift or process signifiers? Nuch
I'm sure they were inspection marks. Each color signified a completed inspection. The special colors do match for SHP, I don't know why. But whenever I see those colors I get wood!
