Old 01-07-2012, 11:37 AM
black69 black69 is offline
Default need help in day2 restoration
I lost the blue helper coil springs that were under this car to keep it from bottoming out.
I got the rocket wheels and tires ready to go back on it.
Air shocks on it (yellow, I think monroe) do lift the car.
questions are, do I and where do I find the right helper coil springs to keep it up? and is that the best way to raise the back end and have it ride as good as it could.
any advice appreciated
I am tempted to have the springs re-arched, or talk to eaton spring in detroit to get new leaf springs with lift built in. Eaton made springs for me once (55 chrysler C300 hemi) and they were perfect and raised the back end.
Old 01-07-2012, 03:08 PM
whitetop whitetop is offline
Default Re: need help in day2 restoration
I would have the springs re-arched by Eaton and use air shocks at a low pressure as back up for when you might hit a bad bump unexpectantly. I would never trust the springs when the tires are directly under the quarter panel..or stick out past the quarter.
You will have to use the Mr Gasket shock extensions again as what was on the car in the photo. They are still available from Mr Gasket in case you lost the originals.
http://www.ebay.com/itm/Mr-Gasket-Shock-...=item4cfd043465
Not sure what you mean by the little helper springs??
Old 01-07-2012, 04:39 PM
here is what I refered to as helper springs
that is what I unfortunately threw out (with the coil bases too)
I will buy those extensions from mr gasket (thank you)
Old 01-07-2012, 04:55 PM
I think you will be fine with just the re-arched springs/air shock combo. Most people back in the day just used air shocks. Original owner probably used the extra springs because the leaf springs were not re-arched and wanted extra security.
It would look cleaner without the extra springs.
Old 01-07-2012, 06:44 PM
thanks for the advice.
Is it safer to have one air fill line per shock?
My gtx and this car have a shared fill line using a T.
Yes it will take more time to fill them, but just makes more sense to me if you hit a pot hole, the air supply is not shared with another shock.
I really have to guard against this thing bottoming out when its done.
Old 01-07-2012, 07:39 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: black69</div><div class="ubbcode-body">thanks for the advice.
</div></div>
Yes, I would run one line per shock and I would never run old or NOS shocks-just for display only. I would run new ones for the street.
Again, if you buy correctly arched springs you should not even need the air shocks for normal driving...but I would have them just for looks and in case you hit a huge bump or pothole as extra insurance.
Old 01-07-2012, 07:13 PM
PxTx's Avatar
PxTx PxTx is offline
There is so much room with those wheels if you got a more favorable offset to run the same size tire under the car without sticking out, is there any consideration for running that way?
Paul III
Old 01-08-2012, 06:39 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body">There is so much room with those wheels if you got a more favorable offset to run the same size tire under the car without sticking out, is there any consideration for running that way? </div></div>
15 x 10 rockets I have wont fit iside the wheel well with the offset on them, with the mickey thompsons.
If I got a custom offset and ran L60 15, then that would fit.
I will check into new air shocks to replace the ones on it, and run separate lines as advised. I knew that made sense.
14 x 6 rockets on front, new good year F 70 14 for now (resusing a set I already have). I recently found out <span style="font-style: italic">concord</span> tires were popular in the day (cant find them now).
I really really like the 2 air gauge idea.
Old 01-08-2012, 12:01 PM
TDW TDW is offline
When a leaf spring is re-arched, it makes the center to center measurement of the eyes closer together. That makes it a lot harder to get them re-installed in the car. I had the ones in my Nova re-arched by a local spring shop. I was not happy with the results. The owner of the spring shop said the springs have a &quot;memory&quot; and would try to go back to their original position. I then had Eaton make me a set with a 2&quot; lift. Much better than the re-arched ones.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
