Hello,
Just wondering if anyone knows what the following flywheel fits: casting #3791021 Date code: L 14 6 (Dec. 14 1966??) It is approx 30lbs, 13" wide measured from top of teeth. Any info will be greatly appreciated!! Tim
timothy moffat |
Most small block applications from 67 through 70 at least. Maybe earlier, maybe later as well. Includes Z/28, L48, LT1 and the Yenko Deuce.
Thanks for info!!!
Tim
timothy moffat |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TDM</div><div class="ubbcode-body">Hello,
Just wondering if anyone knows what the following flywheel fits: casting #3791021 Date code: L 14 6 (Dec. 14 1966??) It is approx 30lbs, 13" wide measured from top of teeth. Any info will be greatly appreciated!! Tim </div></div>*Tim what state are you in,your don't say.
Boston
Thanks Tim,I will try to look it up.
