Old 02-08-2014, 04:59 PM
gthomas gthomas is offline
Default 1970 camaro 3.73 12 bolt
I picked up a 12 bolt out of a 70 camaro (i believe). it has a 3.73 posi in it and the axle code appears to be c oz. Is this a z28 only rear, or available in any 70 camaro. Hope this isn't a dumb question, I am more of a mopar guy. Anyways, the story I got was that it was removed from a 70 z/28 30 years ago. Here is a pic of my 69 camaro I just sold. I love all musclecars. Can't figure out how to add images for some reason.... Figured it ou
Old 02-08-2014, 06:32 PM
Dicky's Avatar
Dicky Dicky is offline
Default Re: 1970 camaro 3.73 12 bolt
It's a '70 only, as that was the last year for 12 bolts in Camaros.
Dicky [img]<<GRAEMLIN_URL>>/flag.gif[/img]
Dicky
Old 02-08-2014, 06:38 PM
jbsides jbsides is offline
Yup, I found out the hard way back in the late 70's with a used one. Expensive lessone, even back then.
From the NastyZ/28 web site:
Rear Axle: GM 12 bolt (only year 12 bolt used). Positraction optional. 3.73:1 ratio standard. 4.10 ratio available (RPO ZQ9).
Old 02-09-2014, 02:35 PM
70 Forest Green Zee's Avatar
70 Z28 only with 4 speed
1970Camaro Z28
Old 02-09-2014, 04:56 PM
iluv69s iluv69s is offline
I had a few 70 SS cars back in the day with original 12 bolts also....(not only Z-28's )
please correct me if I am wrong...
Old 02-09-2014, 05:40 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: iluv69s</div><div class="ubbcode-body">I had a few 70 SS cars back in the day with original 12 bolts also....(not only Z-28's )
please correct me if I am wrong... </div></div>
the COZ stamping is Z28 only with 4 speed. Other Camaros certainly had 12 bolt rear ends but not with a stamping of &quot;COZ&quot; that's all I'm saying
1970Camaro Z28
Old 02-09-2014, 08:38 PM
Thanks for the help.
Old 02-10-2014, 01:19 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 70 Forest Green Zee</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: iluv69s</div><div class="ubbcode-body">I had a few 70 SS cars back in the day with original 12 bolts also....(not only Z-28's )
the COZ stamping is Z28 only with 4 speed. Other Camaros certainly had 12 bolt rear ends but not with a stamping of &quot;COZ&quot; that's all I'm saying </div></div>
I am not arguing, as I don't have the knowledge base to argue this. Just asking.
If I ordered an L78, surely the 3.73:1 posi was available, correct? Not standard, but available.
Why would it be stamped with a different code as opposed to the Z/28?
Old 02-10-2014, 10:44 PM
In regard to the COZ stamping...... after further investigation it appears to have been available with a Turbo 400 as well as a 4 speed in 1970 but still Z28 only. According to what I read in Chevy by the #s the 3:73 posi gear set (COZ) was only available on the 350 Z28 in 1970 and no other Camaro or any other car in the Chevy line. Here's a link to the rear end and gear info posted over at Nasty Z28, a very informative site particularly if you have a second gen Camaro
http://www.nastyz28.com/camaro/camaro70.html#axle
So Gary, in answer to your original question, the rear end that you have came out of a 1970 Z28 buy it could have been an automatic, or a 4 speed.
1970Camaro Z28
Old 02-09-2014, 04:57 PM
..and did a 70 TA use a 12 bolt also??
