Old 07-06-2015, 02:39 AM
Donnie's Avatar
Donnie Donnie is offline
Default 69 396 starter
I need some pics of the starter nose for a 69 L78 if it makes a difference.
also whats right cast or Alum.
cant get my inspection cover on. think I have the wrong nose.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 07-06-2015, 02:08 PM
MosportGreen66's Avatar
Default Re: 69 396 starter
Auto or 4 speed? There are different configurations, and bolt pattern types.
Old 07-06-2015, 02:29 PM
Woj's Avatar
Woj Woj is offline
Automatic.
Old 07-06-2015, 02:30 PM
Should take the aluminum starter cap. Is this a 1108430 starter?
Old 07-06-2015, 04:39 PM
DWR DWR is offline
If you have the build sheet it will show which starter was installed. I believe the 430 starter was not used until 1970. I,m currently looking for a 430 for an early 70 chevelle and not having any luck.
Old 07-06-2015, 07:23 PM
Donnie's Avatar
it has a 430, but I think a 418 is correct for a Feb. 69 L78 turbo 400
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 07-06-2015, 08:54 PM
69VN's Avatar
69VN 69VN is offline
Donnie if you are in need of an aluminum nose housing just shoot me a PM. Have a used GM part# 1968122 nosepiece. I have plenty pics/no issues.
Thanks,
Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 09-27-2017, 12:58 PM
Markyodb2 Markyodb2 is offline
Could the 1107365 be on the 69 396 TH400? Any help out there to clear this up?
Old 09-27-2017, 02:54 PM
McCune McCune is offline
That starter looks up as a lester number 3560 and should have a cast iron housing. The Delco book says that the 69 396 takes a 1108418 which is identical to the 1107365. Auto or manual the 1969 396 uses the same starter.
Old 09-27-2017, 03:05 PM
Thank you for the update. 1108418 with a cast iron housing. had some information on it being the 430 starter. I am assuming the late 68 build on the nova would have the 1108418 then. Assuming that the 1107365 would only be on 68 and prior.
