Wondering who you guys recommend for gray phosphate coating for hood hinges and latches for my other 68 nova ss....lookin for shop that does a good job with reasonable turn around time.. thanks in advance,Chris Teed
69 camaro Z-28 burnished brown X-77 bought 1978 70 camaro Z28 forest green M40 black vinyl roof PROJECT 99 camaro SS Hugger Orange 6speed no t-tops 1 of 54 11 cts-v black diamond edition wagon 556hp GONE 15 camaro Z/28 white AC brand new |
If you can get the parts media blasted locally you can do it yourself very easily and cheap.
http://www.palmettoenterprises.net/P...-Welcome-.html
It does create a bit of an odor, but you can obtain great results doing it outside on a grill. Learned that tip from Charlie.
How durable is this coating -- like factory? Thanks
I can't tell any difference. Get something like a stainless salad bowl etc from Walmart that is big enough to hold the parts you want coated, put some solution and water in it on a outdoor bar-b-q and get it hot. Put the parts in and make nut and bolt soup. Have some tongs or a ladle for lifting the parts out to check on the color. When the parts are dark enough for your liking take them out, rinse and then coat with something like WD40.
There are many good links on the interweb and Youtube that deal with phosphate coating. I just use Prep and Etch from the box store, about 15 bux a gallon. Oven proof glass ware works good for small stuff.
Here is one Home brew phosphate Mike |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">There are many good links on the interweb and Youtube that deal with phosphate coating. I just use Prep and Etch from the box store, about 15 bux a gallon. Oven proof glass ware works good for small stuff.
Here is one Home brew phosphate Mike </div></div> This is the method I am using. I use a hot plate for bolts and small brackets. |
And a word of caution with the hot plate, do not get it to hot, makes a foamy mess.. [img]<<GRAEMLIN_URL>>/shocked.gif[/img]
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">And a word of caution with the hot plate, do not get it to hot, makes a foamy mess.. [img]<<GRAEMLIN_URL>>/shocked.gif[/img] </div></div>
Yes great tip. I know this from experience; keep it around 185*F / 85*C... [img]<<GRAEMLIN_URL>>/beers.gif[/img] |
