Old 03-03-2016, 03:38 PM
Default Raw Casting ZL-1 Block
Raw Casting ZL1 Block on eBay
Is there any way the bids on this block could be real? Even if all the machining was done, wouldn't the block still not have cast in water passages?
Jason
Old 03-03-2016, 04:29 PM
the427king's Avatar
Default Re: Raw Casting ZL-1 Block
Simply a display item..
No Fisher priced toys here
Old 03-03-2016, 04:51 PM
x77-69z28's Avatar
That would be one expensive coffee table!
Buddy
Old 03-03-2016, 08:19 PM
markus37 markus37 is offline
I have records on many solid blocks that Yenko cast, typically for drag racers.A lot of that history is in my newest book.." The Yenko Era..
Continued. Canonsburg and beyond "
Old 03-04-2016, 03:53 PM
MarcDant's Avatar
MarcDant MarcDant is offline
The cores in the cooling cavity of the block are usually made of silica sand,when the block is machined the sand exits from the frost plug and cooling holes.They usually go on a vibrating machine to loosen the particles of sand.Theres more to the process then i mentioned.
Old 03-04-2016, 04:19 PM
I see, that is interesting. Thanks for explaining.
Jason
Old 03-04-2016, 11:28 PM
ds1 ds1 is offline
They show a picture of the part number on the back of the block. But there is no casting date on the driver side of the block. Another tall Ebay story? It could be true. But event preproduction parts have casting numbers and dates. I checked my pictures of the block I had to confirm my suspicion.
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
Old 03-04-2016, 11:46 PM
I too would believe the core still has sand in it. Isn't there a way to check to see if there are hollow cavities? Tapping would surely give some type of indication.
Were the Aluminum blocks broached or did they use a rotary cutter?
Old 03-04-2016, 11:55 PM
bergy's Avatar
bergy bergy is offline
There is no water jacket core - if the core was there, it would have printed at the freeze plug. Aluminum blocks were milled (rotary cutter)
Old 03-05-2016, 06:29 AM
MarcDant's Avatar
Do zl 1 cylinder heads interchange with L 88 heads if so how do the heads get coolant circulation from a zl 1 aluminum block to a L 88 cast iron block.Yes they use dry blocks for drag racing because the engine only runs for 2 or 3 minutes,no need for coolant.Thanks marc.
