Old 05-17-2016, 12:36 PM
Hotrodpaul Hotrodpaul is online now
Default 69 Z-28 Survivor Intake question
I recently purchased a survivor 69 Z-28 intake with original thermo housing, plugs, and fittings. The vacuum line fitting at the rear of the intake has two outlets, one for the Brake Booster and another one 180 degrees from the booster barb. What is this 2nd outlet barb used for? Possible vacuum for RS headlights? I can post some pics if needed.
Thanks, Paul
Old 05-17-2016, 01:26 PM
x77-69z28's Avatar
Default Re: 69 Z-28 Survivor Intake question
RS is correct. Nice piece
Old 05-17-2016, 07:32 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x77-69z28</div><div class="ubbcode-body">RS is correct. Nice piece</div></div>
Yes, for a RS. Have one on mine.
Old 05-17-2016, 05:21 PM
earntaz earntaz is offline
Were those 69 Z-cars available with and automatic? If so, that vac could be for the modulator.
Old 05-17-2016, 05:23 PM
Fast67VelleN2O's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Were those 69 Z-cars available with and automatic? If so, that vac could be for the modulator. </div></div>
No automatic available with the Z28.
Day 2 is Life.
Old 05-17-2016, 05:38 PM
or I believe traction compound applicators used that port.
Survivors, restored cars, &amp; other photos
Old 05-17-2016, 07:10 PM
I have a similar fitting on my 70 Z-28 for the vacuum line for the Turbo 400.
Paul
Old 05-17-2016, 07:44 PM
Interesting to note that there is still traces of aluminum paint on the intake. Did they touch these up on the assy line with paint? I had heard the intake bolts were painted silver possibly with a brush after the engine was assembled.
Paul
Old 05-17-2016, 08:00 PM
----I can only speak for mid-year Corvettes but suspect that all small-block aluminum intake engines would have been the same. At Classic Motors we bought and sold many, many cars that came to us as original and untouched. Almost all of them showed traces of silver paint on the intakes, mostly along the edge of the intakes and heads. The silver paint actually extended on to the valve-covers in varying amounts. Hope this helps.......Bill S
Old 05-17-2016, 09:41 PM
SS427's Avatar
SS427 SS427 is offline
Charley's old (now Jason's) 1100 mile 70 Z28 showed many signs of silver paint on the intake bolts as well as orange brushed on paint on the plug wire stands if I recall correctly. Different year but likely same technique used.
Rick Nelson
