Old 10-17-2016, 02:02 PM
Default '69 brake distribution valve function
I asked this question on the Chevelle site but no answers yet. My ELC has drum-drum brakes and I can't seem to get the rears bled properly. There is almost no flow of fluid. The system is all stock with a rebuilt master and new wheel cylinders. My question is: does that valve partially close off the front or rear if there is a leak or an open line? I've looked at the pin inside that is under the switch and all I see is a straight smooth pin. I don't see anything that would cause it to activate the switch. I want to know if that valve could be my problem or if I should look elsewhere.
thanks
Verne
Old 10-17-2016, 02:50 PM
jl8z28 jl8z28 is offline
Default Re: '69 brake distribution valve function
Take the master cylinder cover off and open the bleeders on the back just let it sit I usally leave it over night unless the fluid starts to come out sooner then if still dosent work get one of the brake bleeders that draws the fluid from the bleeder screws
Old 10-17-2016, 03:10 PM
ssl78 ssl78 is offline
Did you check the rubber brake line at the rear that goes into the junction block. That line gets plugged and will not let fluid go thru
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 10-17-2016, 03:32 PM
I plan on checking that too, but I NEED to know if that distribution valve can close off flow.
I have no bleeder screws on the master.
Verne
Old 10-17-2016, 03:50 PM
That doesn't matter you can draw the fluid from the bleeder on the rear cylinder
Old 10-17-2016, 03:57 PM
Now I understand what you're saying. You're talking about gravity bleeding.
Before I check anything else, I'd like to know if that valve could be preventing the fluid flow to the rear. IF it is, no kind of bleeding will work. THAT is the question I'm looking for an answer to.
Verne
Old 10-17-2016, 04:05 PM
m22mike's Avatar
m22mike m22mike is offline
Verne
Here is a 70 differential pressure valve. I think 67 through 70 are the same inside, it is just a simple spool valve. You can see the internals here. It can restrict fluid if the spool is shifted from differential pressure, and they can stick. They are not hard to take apart and clean.
Distribution / press diff block
Old 10-17-2016, 04:22 PM
Thanks Mike. Those components are very similar to mine but a little different. On the plus side, I can see the smooth brass rod directly under the safety switch, so it appears that it is not diverted to one end or the other (blocking of any flow). IF that is the case, I'll assume the valve is not my problem. I'll look for kinks in the line to the rear first, then replace the rear hose and see where I am after that.
Verne
Old 10-17-2016, 04:42 PM
I had the same problem with my camaro and before you change something try what I said
Old 10-18-2016, 12:33 AM
Try breaking the steel brake line loose where it goes into the rear rubber line see if you get a good flow of fluid there.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
