Old 11-24-2016, 02:04 PM
Edgemontvillage's Avatar
Default 1969 Camaro Clock Adjustment Knob - LOCATED!
Looking for a detail part for my 1969 Camaro (dash cluster mounted) clock, a mint or NOS <span style="font-weight: bold">clock adjustment knob</span>. The NOS versions I have seen on-line have only a partially fluted body and are incorrect. Its probably too small to have re-chromed. <span style="font-weight: bold">Please PM if you can help. </span>
Old 11-24-2016, 04:45 PM
enio45 enio45 is offline
Default Re: 1969 Camaro Clock Adjustment Knob
is it plastic or metal??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-25-2016, 03:05 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">is it plastic or metal?? </div></div>
Eddie, I checked this morning and can't determine if the knob is plastic or metal (without destroying it). Its lightweight however hollow. Considering the force required to pull the adjustment stem and rotate the gear mechanism I'd say it could be metal?
Old 11-24-2016, 08:57 PM
68l30's Avatar
68l30 68l30 is offline
I may have one....Let me look once I get home.
BIG
Old 11-26-2016, 12:52 PM
metal we can get it rechromed - my guy here does a lot of very small intricate plating for me for the ferrari
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-26-2016, 02:42 PM
68l30's Avatar
I checked my stash. Mine must be 70-72 as they are missing the flutes...
BIG
Old 11-26-2016, 03:57 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 68l30</div><div class="ubbcode-body">I checked my stash. Mine must be 70-72 as they are missing the flutes...
BIG </div></div>
Thanks for checking Steve.
Old 11-26-2016, 04:18 PM
68l30's Avatar
Np, I have another tub of clocks I need to dig out. If I have another it will be on a clock, I'd gladly part with it.
BIG
Old 11-27-2016, 03:17 PM
Steve, please have a look and if you can locate is a nice adjustment knob let me know.
Old 12-15-2016, 03:31 AM
I located a NOS clock knob PN# 3794017 which decodes as a Corvette part however is exactly the same size and with the same fluting detail as the original. <span style="font-weight: bold">A shout-out to SYC member BILLOHIO </span>for his help with this search. Lloyd.
