Old 03-12-2017, 06:50 AM
68 DANA's Avatar
68 DANA 68 DANA is offline
Question 1967-1969 Delco Energizer R-59 Maintenance-Free Battery
There are a couple of manufacturers (Antique Auto Battery and Restoration Battery) that are currently producing the original style Delco R-59 date coded battery. The batteries are Maintenance Free with "AGM" (absorbent glass mat) technology. The companies clam that the batteries feature the authentic look of the original assembly line battery and are available date coded for the detailed restorer.
Does anyone have any experience with these companies and how close do the batteries resemble the original factory style battery that was offered back in the day?
Old 03-12-2017, 12:13 PM
I bought three R-59's from both companies an have no complaints today.
They are both going strong after 10 years.I use a trickle charger on all year round.
They resemble the originals very well.
I talked to Tom @ RB & instead date coded mine myself with a heat stamp.
Old 03-12-2017, 06:01 PM
Mr70, Your advice on correct restoration battery for 01C 70 Camaro (L-78)
and 07E 70 Camaro (Z-28) (No Post/Side Connect)
Can you show dated heat stamp and how does one arrange for that ??
Thank You
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 03-13-2017, 12:13 AM
Billohio Billohio is online now
Trickle charger is a key.
I have a battery that was about 4 years old and it would start the car twice and nothing after charging. Got it in the trailer one day, got to the show and dead.
Bill
Old 03-13-2017, 12:18 AM
ALLZS ALLZS is online now
Anyone reproduceing the correct y77 side post battery with yellow lettering ?
Old 03-13-2017, 12:51 AM
jl8z28 jl8z28 is online now
No
Old 03-13-2017, 03:27 PM
The repop batteries i had lasted me only 5yrs. Most people i have talked too had them last less. That's a lot of money to spend for something that lasts 5 yrs. So, now i get a modern battery with the topper. They are already going on 6 &7 years old, and i do use a battery tender.
Old 03-13-2017, 04:20 PM
wheelhop wheelhop is offline
My first R-59 reproduction battery lasted 8 years, just bought another one this past summer.
One of the things you need to keep in mind is the type of charger you are using on them.
they come with specific instructions.
Old 03-13-2017, 06:28 PM
68 DANA's Avatar
It sounds like you and Mr.70 have had some success with the batteries, however others have not. I did check the charging instructions from the manufacturer and for optimum life the voltage should be maintained around 12.8 volts. Should the battery require charging, charge the battery using a charger with a 10amp-12amp range for 2 hours. They are very specific that the charger's output voltage must not exceed 15V.
Perhaps not maintaining the battery accounts for the premature battery life
Old 03-13-2017, 07:03 PM
I have a repro R-59 (can't remember vendor) that I use a "Battery Tender" trickle charger specifically designed for the gel technology that the battery uses. Off of the top of my head, I have had the battery for at least 6 yrs.
