Old 06-02-2017, 03:51 AM
Default Ball Joints : Bolting ????
I'm using Bolt In Upper Ball Joints in my driver 73 Camaro R/S project.
I'm thinking to use 1/4-20x1" Button Head Allen Bolts for a more
"rivet like" appearance. Not sure what kind of nut (grade 8 ??) my
fastener store can offer me.
Ball Joints made off shore did not come with (metric ??) zirc fitting !!!!
Any problem with this idea ???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-02-2017, 11:36 AM
WILMASBOYL78's Avatar
Default Rivets..
After you install the allen head bolts use a little 'all-metal' filler to hide the hex shaped hole..smooth it over...finish with some cast steel paint and the average Joe won't know the difference.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 06-02-2017, 12:39 PM
earntaz earntaz is offline
I would use grade 8 fasteners (bolt/nut) ... TAZ
Old 06-02-2017, 01:04 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Most of the Corvette restoration parts houses sell the threaded "rivet" for this application
http://www.zip-corvette.com/68-82-c3...t-nut-set.html
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 01:31 PM
Default rivets/bolts..
Do those Corvette fasteners have an 'allen head' ...can't tell from the photo.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 06-02-2017, 01:40 PM
RPOLS3's Avatar
-wilma
Typically they do not and from the top look just like the rivets - so no need to fill anything in. They are sold from other vendors as well.
Ground up sells this kit which the rivets look a little different than the Corvette guys.
http://www.ss396.com/chevelle/DRVT-33.html
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 02:24 PM
Default rivet/bolts..
What holds the bolt in place as the nut is tightened??
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 06-02-2017, 05:11 PM
Thanks for you replies.......
As I said this is a nice street, driver build.....
I called local fastener supplier and they carry 1/4-20x1"
Button Head Allen in Grade 8 Black Oxide.
Not trying to trick anybody into thinking these are rivits,
just didnt like the cosmetics of regular hex head.
I will use AN washers against the powder coated A-Arm
and thread locker....need to find inch lb torque for above
I'll post pics upon completion !!
Chuck Sharin
[email protected]
