Old 09-21-2017, 02:24 PM
Tommy Tommy is offline
Default headers and angle plug head question
This is not a normal cylinder head I would have bought but I ended up with them. I have a small block with a set of older AFR angle plug heads that I'm installing in a 68 Nova. The heads are the early early AFR heads with a large "A" on the exhaust manifold side but look like regular small block heads otherwise. The old Hooker, Black Jacks and Summit headers I have won't work with these Angle plug heads. Anyone dealt with this in a 68-72Nova or 67-69 Camaro? I need a decent set of long tube headers that are known to fit with minor dimpling not an issue.
Tommy
Old 09-21-2017, 02:32 PM
scuncio scuncio is online now
Yes! Hooker 17/8" primary Super Comps. Pretty sure I have a nice set,
Tommy (09-22-2017)
Old 09-21-2017, 02:50 PM
Interesting. What did you have those things in?
Tommy
Old 09-26-2017, 02:32 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Tommy, are you going with power steering on that car? How are you mounting the bracket that would normally go to the manifold...? current issue I have with the same heads
TIA
I ain't nobody, dork.
Old 09-26-2017, 10:43 PM
No, mine is manual steering. I did find headers by the way Thanks to Tony (Scuncio).
Tommy
