Old 10-18-2017, 04:17 PM
69novamanrick 69novamanrick is offline
Default Julian Date For 9204 Booster
I have a 1969 Nova built 05C, the 3rd week of May, in Willow Run Michigan, and I need to know what the best Julian calendar date would be for a 9204 Brake Booster. What is the correct back figure, as far as how far back from the build code, would be the correct Julian Calendar Date, for the 9204 booster for this car? Would I be looking for a 99 or a 121 Julian Calendar Date, or something further back, or something closer to the Build Code of the 05C? I just need the rule of thumb or what is correct so I can find what I need for this car. Thanks everyone!
Attachments - The Supercar Registry BoosterBrake.9200.Date56.69Camaro.D.jpg BoosterBrake.9200.Date56.69Camaro.b.jpg 70Z28.9204.Restored.jpg 20180403_223445.jpg
Old 10-19-2017, 04:05 PM
x77-69z28's Avatar
For reference, my 05A Z/28 has a 120 dated 9204.
Buddy
The Following User Says Thank You to x77-69z28 For This Useful Post:
69novamanrick (10-19-2017)
Old 10-19-2017, 05:44 PM
Thank you so kindly!
Old 10-19-2017, 07:06 PM
Spooky's Avatar
Spooky Spooky is offline
My 02B camaro delivered Feb 13 has a booster dated 39. It is super close to the build date.
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
The Following User Says Thank You to Spooky For This Useful Post:
69novamanrick (10-20-2017)
Old 10-19-2017, 08:11 PM
the427king's Avatar
Have an 02d w a 042 booster
No Fisher priced toys here
The Following User Says Thank You to the427king For This Useful Post:
Old 10-20-2017, 06:02 PM
Thanks everyone for the input on this booster date and build date info!
Old 10-23-2017, 04:02 PM
Zman1969 Zman1969 is offline
so is it a known fact that 69 Nova's had 9204's same as 69 camaro? I tried to find this info out couple years back when I had a Nova
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 10-23-2017, 09:30 PM
Yes that is a known fact. I've had 4 69 Nova's that each one had the 9204 Booster. Same thing as the Big Block having the 13/16 sway bar verses the small block 11/16 sway bar, the Big Block heater cores, the Big Block inner heater box, the frame mounts, coil springs, and so forth. Pretty much everything was the same on the subframe and firewall for 69 Camaro and Nova.
Old 10-23-2017, 09:53 PM
Originally Posted by 69novamanrick View Post
Yes that is a known fact. I've had 4 69 Nova's that each one had the 9204 Booster. Same thing as the Big Block 13/16 sway bar, the Big Block heater cores, the Big Block inner heater box, the frame mounts, coil springs, and so forth.
thanks I searched Novas.net and Steves novasite and couldnt get confirmation of that
I dont think that all has 13/16 sway bar did they?
90 Formula 350
Old 10-23-2017, 10:59 PM
You are correct on the 13/16 sway bar. Only the Big Block cars would have came with that option. The small block v-8 came with a 11/16 sway bar. I have seen where most 6 cylinder cars did NOT have a sway bar, yet I have seen a couple where they did have a 11/16 sway bar. I've yet to confirm any of that but that's what I have witnessed over the years. Also, I might add, that there were some cars with power brakes that did NOT come with the 9204 booster. The majority of the 9204 boosters that I have found were for power disc brake hi performance cars and Big Block applications. Again, this is what I've verified or witnessed over the years.
Tags
9204 pdb booster
