Last weekend I bought a Camaro from a guy who used to own a documented RS COPO years ago. He had installed the original cowl induction air cleaner from the COPO on the car I purchased, and I'd like to understand exactly what I have. It appears to be an assembly line correct flat-bottom base with an incorrect chromed open element air cleaner lid, but with the correct hood sealing flange. Obviously it's a major bummer that the snorkel was hacked but I'm guessing that can be replaced by someone who knows what he's doing.
The decal was a new repop, something the previous owner installed a couple years ago. Any advice would be much appreciated! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
I have a snorkel removed from a over the counter replacement assembly if your interested.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
PM sent
Neat piece! Sorry I can’t add any comments... but I’d sure like to hear more about the Camaro you bought!
In production, L34, L35, L78 & both COPOs used the #6485235 air cleaner assembly. Also used on Z/28 with an extension not used on 396/427. So it is not particularly rare.
Sometime after July '69, the base was revised with a bead to raise the lid for better air flow. Some cars built after that time have the revised base. GMPD serviced the 2nd design #6485235 well into the '80s with another revision; a vent tube with 2 45º bends to clear a Holley double-pumper. GMPD also serviced the seal flange but mostly the version used on Chevelles, notched to clear a vacuum pod used on A/C cars. Your unit has an original flange. The flat-bottom base is a plus but needs a little work and a lid as noted and is rusty. I suspect that isn't the original seal. Were it complete and in excellent original condition, it would be a great find. Working against you, the flat bottom ZL2 air cleaner, lid, flange and seal are nicely reproduced for about $250. Last edited by William; 03-29-2018 at 03:34 AM. |
![]() Quote:
I cannot see how that would improve airflow. Granted the repop is nice but its still a repop.
![]() Quote:
I have had several flat bottoms and the element sealed to the base just fine. |
Restore it. Base looks really solid. You already have a line on a snorkle. You have the most important part and having the tube is a big big plus.
Appreciate the feedback guys. The base is in excellent shape save the obvious snorkel hack job.
Does the rubber seal seam have tape on it?
If so,please show it close up & from different angles.. |
