Old 11-28-2018, 06:31 PM
Caseys69 Caseys69 is offline
Default 67 A Body Frame
I am looking for a 67 A body convertible frame. I believe chevelle, gto, lemans, cutlass, and skylark are all the same. I will consider a parts car IF the frame is clean.
Casey
708 287 2914
Willing to travel
Old 11-28-2018, 10:04 PM
marxjunk marxjunk is offline
chevelle is chevelle only..its shorter overall
cutlass is diff in the front for the huge cross flow radiator
skylark and gto are the same
67 is 67
4 doors interchange with 2 doors in the early years...
lemans and skylark work under a chevelle, but you have to chop them up in the rear to shorten them
convert is tuff to get anymore...real tuff
so what are you working on?
Mark
The Following User Says Thank You to marxjunk For This Useful Post:
PeteLeathersac (11-28-2018)
Old 11-28-2018, 10:58 PM
DEUCE DEUCE is offline
Default 67 Chevelle frame
I have a nice clean regular 67 Chevelle frame from out west.
Mike
Old 11-29-2018, 12:59 AM
67 SS convert. The frame was absolutely trashed. From what i understand skylark, gto, and el camino will work but need to be shortened behind the rear axle area. Is that right?
Old 11-29-2018, 02:22 AM
yes..chop the rear..theres stuff all over the internet...it actually has to be sectioned, you just dont cut the rear cross member off and move it..
personally..find a nice hardtop frame or 4 door frame ( the four door is how you steal one)..and buy the helwig frame FX boxing kit...it could really pass as a stock boxed frame, unless you had it on a lift..plus it picks up an extra body mount and makes it ride better..done it more than a few times
67 is 67 because of the 400 turbo and the rear spring pockets, you could modify an early one by using your trans brackets and the spring pockets in the rear...
then you could get a 64-67..
i just sold a 67 lemans convert frame bare for 3K i could have gotten more...but i threw a ridiculous number out and he jumped..i didnt really want to sell it ..they are so hard to get...almost impossible in 2018
all 65-67 GS Buicks have convert frames...all of them, originally..coupe hardtop etc..its part of the GS package
Mark
Caseys69 (11-29-2018)
Old 11-29-2018, 03:36 AM
Thanka for all the info Mark, i appreciate it!
