I know where a 69 pan is available. Assembly line correct; not one of the over the counter pans. Aren't 68 and 69 identical except for the drain plug?
I am not sure if they are the same. Can anyone confirm they are the same?
Apparently 67 and 68 Z used pan 3927134
69 used pan 3974251 I know for certain that the drain plug is different. 67-68 used the large hex head drain plug. 69 used the smaller 9/16 hex head with the same thread. I also believe that even a slight change (like the different drain plug) would call for a different part number. But I don't know if there are any OTHER differences in the two pans. Can anyone help this member out? Surely with all the knowledge on this board, someone knows.
Thank you for the information!
The 68 oil pan uses the same 9/16 hex size drain plug . I have a really nice true assembly line 68 z pan I would sell . Call or text thanks
