Old 05-02-2019, 01:17 PM
Slob44 Slob44 is offline
Default 1969 Chevelle grille repair
i have my original grille and there is a broken tab, i have the tab and want to repair it....what is the best "glue" to use? i tried some hardware store glues and they did not work.
Old 05-02-2019, 03:02 PM
tunes's Avatar
tunes tunes is offline
I used this on the dash of my El Camino and it's held up real well. You might try it. 3M Scotch-Weld Industrial Plastic Adhesive #4475.
Robert
_______________
2023 Stingray Coupe Z51
Old 05-02-2019, 03:14 PM
I've used that 3M #4475 Industrial Plastic Adhesive and have no complaints.It's flexible to some degree too.
Old 05-02-2019, 05:54 PM
If it's made of ABS then you can use ABS glue for ABS pipe. I've used this on dashes to glue the pegs on that hold the wiper switch and it works well. You can also try using Acetone. ABS dissolves in acetone, so if you put just a little on both pieces and let it start to dissolve then you can stick them together.
L78M22Rag (05-02-2019)
