Old 06-21-2019, 01:05 PM
Default Door Hinge Alternatives
A friend needs some hinges rebuilt or replaced. Do the DIY kits work? Are the repos any good? Is there someone out there that does a good job rebuilding them?
Old 06-21-2019, 02:26 PM
I put new bushings and pins in mine. Pretty easy job. If the bushings are worn all the way through and the hole in the hinge is also worn then the hole can be welded and drilled. I've also done that.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
earntaz (06-22-2019), travlnz28 (06-23-2019)
Old 06-21-2019, 10:50 PM
scuncio scuncio is online now
Agree, not a bad DIY project.
Old 06-22-2019, 02:16 AM
169indy's Avatar
169indy 169indy is offline
Suggested vendor
Willie Wilson
Wilson Antique Car Parts
1067 Clearview Drive
Forest, VA 24551
434-258-2606
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
