Old 06-23-2019, 10:22 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Default What was bolted here?
Curious if anybody knows what may have been bolted to this Camaro passenger side front wheel well. The diagonal bolt pattern measures approximately 4.25" across. Thanks for any help.
Attachments - The Supercar Registry Picture0624192251_1.jpg IMG_5192.jpg IMG_5191.jpg
Old 06-24-2019, 01:13 AM
Lynn Lynn is online now
What year?
Another pic from farther away would be helpful (maybe).
Old 06-24-2019, 02:05 AM
1967Z28's Avatar
It's from a '68 Camaro. The square hole holds the loop bracket that restrains the two heater hoses going from the heater core to the engine. The black area in the lower right of the picture is where the a-arm flap would be.
The holes may be for a NOx smog control box that used to get put on CA cars back in the '70s but those usually got mounted on the firewall.
Old 06-25-2019, 04:16 AM
67since67's Avatar
I removed this one from a SoCal '67 396 Chevelle decades ago, it was mounted on the firewall. The bolt spread is 2 1/4", other boxes may have had a wider spread??
A cool can would likely have been more horizontally mounted? Fuel pressure regulator?
Old 06-24-2019, 09:32 PM
Are those holes factory punched? Holes look elongated, like someone drilled them after purchasing the car.
- Warren
Old 06-24-2019, 11:52 PM
1967Z28's Avatar
Warren, no they were not factory punched. I'm guessing they were drilled by somebody back in the '70s.
