Old 01-27-2020, 03:21 AM
Default 1969 SBC Exhaust Heat Shields Needed - Pair
This blue 69 Z that I am going through right now was missing a pair of original spark plug heat shields on the driver's side. I'm pretty sure all 4 are exactly the same regardless of the side they are mounted on and could use a pair of originals if someone has a spare set.
Let me know if you have a decent original pair you could sell.
Thanks...G
Attachments - The Supercar Registry IMG_6041.JPG IMG_6040.JPG IMG_6039.JPG IMG_6038.JPG
Old 01-27-2020, 05:25 AM
Lynn Lynn is online now
I believe you are correct; they are the same from side to side.
However, IIRC (big if right now) there were two sets of holes, and a different set was used for each side. That means that if you find a nice set that was used on the right side, those unused holes will have some scars showing when you mount them on the left side.
Someone with more recent experience can correct me if I am wrong.
NorCam (01-27-2020)
Old 01-27-2020, 11:13 PM
Not the same for there are two that are welded and two that bolts on. Dave
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
The Following 2 Users Say Thank You to luv2sixty9 For This Useful Post:
m22mike (04-26-2020), NorCam (01-28-2020)
Old 01-28-2020, 01:44 AM
Looks like they are the same. I flipped the pair I have to the driver's side and the bolt holes align on the block as long as I end up finding the same offset tabs as shown below. Looking for a pair like these.
Old 04-13-2020, 07:47 PM
Still looking for a pair of original heat shields.
Anyone?
Old 04-18-2020, 02:44 PM
lbnaz lbnaz is offline
Yenko Premier Member
Default Heat Shields
Not sure if this would help. They all came off a 69 Impala 350/300hp. Larry
Old 04-24-2020, 02:42 AM
No. But thank you for the reply and such.
The wrong style though.
Old 04-25-2020, 09:22 PM
How about these?
Old 04-25-2020, 09:28 PM
I have now found a set of shields.
Thanks sYc
