NOS GM ignition wire holder. Fits Z/28 as well as Big Blocks. It has the correct "AR"
stamped on the side. 1969-1970 Camaro Z/28 (302 + 350). 1969-1970 Camaro 396, 427, + 454 (With factory A/C) (Except Special High Performance). ***************SOLD************** -------------------------------------------------------------------------------------------------------------------------------- (12)NOS GM negative battery cable bolts. These negative bolts have the smaller 5/16" diameter thread bolt with 7/16" hex head. GM used this smaller thread bolt for the negative cable on the 1969-1970 side post batteries. The negative bolt will only work with a original GM battery because the later batteries use larger 3/8 thread. 1969-1970 Camaro. 1969-1970 Corvette. 1970 Chevelle, Malibu, El Camino. 1970 ChevyII Nova. 1970 Pontiac G.T.O., LeMans, + Tempest. 1969-1970 Pontiac Firebird. ***************SOLD************** -------------------------------------------------------------------------------------------------------------------------------- NOS GM brake booster check valve. Comes with rubber grommet as well. 1967-1972 Camaro, Chevelle, + Chevy II Nova. 1964-1972 Corvette. 1967-1972 Pontiac Firebird. 1964-1972 Pontiac GTO/Tempest/Lemans. 1965-1972 Oldsmobile Cutlass/F85/442. 1968-1972 Buick Skylark/Gran Sport/GSX. ***************SOLD************** ------------------------------------------------------------------------------------------------------------------------------ NOS GM Muncie 4-Speed input shaft bearing. Goes between the input shaft and the main shaft and fits the M-20, M-21, + M-22. 1964-1972 Camaro, Chevelle, Corvette, + ChevyII Nova. 1964-1972 Chevrolet Impala, Caprice, Biscayne, + Bel-Air (Except 1969 model year). 1964-1972 Pontiac G.T.O., LeMans, Tempest, Grand Prix, + Firebird. 1964-1972 Oldsmobile Cutlass, F-85, 442. 1968-1972 Buick Skylark, Special, + Gran Sport. ***************SOLD************** ------------------------------------------------------------------------------------------------------------------------------ NOS GM Delco-Remy Distributor MS 201 vacuum advance. Also included is a set of NOS Delco-Remy Heavy Duty points. 1969-1970 Camaro Z/28. 1969 Camaro, Chevelle. + Nova (396) (L34 or L35 only). ***************SOLD************** Thanks, Sam GRAFFZ Last edited by GRAFFZ; 02-23-2020 at 07:03 PM. Reason: Items are sold. |
