Old 07-09-2020, 09:45 PM
bbbentley's Avatar
Default ZL1 Cam Cold Lash
From what I could find, the 9181 ZL1 has a hot lash of I=.024, E=.026 ? Anyone care to give a cold lash setting? I’m guessing subtract .002 off the above specs? Any help appreciated. Thanks sYc.
FULL OWNER HISTORY
Old 07-09-2020, 10:43 PM
L_e_e's Avatar
L_e_e L_e_e is offline
With iron heads you want to ADD 0.002"
The Following User Says Thank You to L_e_e For This Useful Post:
bbbentley (07-10-2020)
Old 07-09-2020, 11:34 PM
jerry455 jerry455 is offline
What if engine has factory aluminum heads? Still add .002?
Old 07-10-2020, 12:06 AM
lbnaz lbnaz is offline
Yenko Premier Member
I set mine as per specs w/alum heads and had no issue. Larry
Old 07-10-2020, 12:22 AM
RobR RobR is offline
Head material?
Block material?
Old 07-10-2020, 12:24 AM
bbbentley's Avatar
Originally Posted by RobR View Post
Head material?
Block material?
Iron&iron. Basic L72 w zl1cam
FULL OWNER HISTORY
Old 07-10-2020, 12:31 AM
rszmjt rszmjt is offline
Iron heads & block add .002. With aluminum heads set cold lash tighter about .005-.006 on a rat motor. If it’s aluminum block & heads about .010 tighter cold. The thermal expansion of aluminum causes the lash to increase hot.
The Following 3 Users Say Thank You to rszmjt For This Useful Post:
bbbentley (07-10-2020), jerry455 (07-10-2020), L_e_e (07-10-2020)
Old 07-10-2020, 12:46 AM
Like you said, I would go .002” LESS than the hot lash spec. ‪for break-in.‬ Then
‪with the engine at running temp, shut it off, and set the valves on one cylinder to the Hot lash on the cam card.‬
‪Let the engine fully cool down. ‬
‪Measure the lash on that cylinder that you set hot.‬
‪That will be the cold lash setting to use on all the cylinders.‬
The Following 2 Users Say Thank You to RobR For This Useful Post:
Old 07-10-2020, 08:56 AM
bbbentley's Avatar
Trusting my own experience, and your reassurance, I set them .002 tighter or I.022-E.024. Great idea on the reverse calculating lash method.
FULL OWNER HISTORY
The Following 2 Users Say Thank You to bbbentley For This Useful Post:
jerry455 (07-10-2020), RobR (07-10-2020)
Old 07-10-2020, 04:43 PM
napa68 napa68 is offline
While this document revolves around small blocks, the principles apply. These suggestions are with iron block and heads. This procedure works VERY well IMO
http://www.metroli.org/pdf/WHITE%20P...Adjustment.pdf
