Old 04-18-2021, 07:28 PM
MJV1953 MJV1953 is offline
Default Rear window defroster motor rebuild
My rear window motor just barely turns. Who would you send it to for a rebuild? Thanks, Mike
Old 04-19-2021, 12:47 AM
thehornworks thehornworks is offline
Take the squirrel cage off and put some light weight oil down the shaft. The top bearings get dirt in them .
Old 04-19-2021, 01:22 PM
rszmjt rszmjt is offline
X2 on that. Guy I work for has a 69 L89 and the rear defroster would blow the fuse instantly, took defroster off and it was super stiff, took the squirrel cage off and used some WD 40 to free up the top and bottom bsgs. Then relubed with some light oil ,worked perfect after.
Old 04-20-2021, 01:28 AM
ban617 ban617 is offline
Hi , another thing to do is check your voltage & ground at the motor & voltage in & out of the switch....
